| Welcome, Guest |
| Latest Threads |
Astra J 2014. Electric st...
8:th-Sep-2025, 21:22:49
Factory Reverse Camera, A...
Forum: Retrofit How-to's
Last Post: obsidian
30:th-Aug-2025, 20:00:16
» Replies: 34
| Exterior roof trim needs replaced |
Posted by: hughg176 - 18:th-Aug-2020, 05:59:07 - Forum: Astra-J/GTC
- Replies (1)
Have a 2011 astra j and the roof rails/bars are totally peeling they look awful and need replaced does anyone know where I could buy some and if they are easy to take off & replace? I
I can't find any online but I think iv found the part numbers
OPEL catalogue nr: 187331
Part Number GM: 13270834, 13314191
Cover, gutter, left (production number. 13270834 – FREE UK Delivery
| cd 400 plus |
Posted by: Andy1012345 - 16:th-Aug-2020, 19:23:44 - Forum: Large Cars Zafira, Mokka & Antara
- Replies (10)
Hey just after some advice i have just bought a zafira tourer 2015 it has the cd400 plus system with dab however no Bluetooth, my old car is the astra j with the cd400 but it has Bluetooth is it possible to take the Bluetooth module out of the astra and put it in to the tourer?
Many thanks
Andy
| Astra J 1.4T Overheating |
Posted by: Bear - 16:th-Aug-2020, 13:43:33 - Forum: Astra-J/GTC
- Replies (3)
Hi all looking for advice
My Astra has recently started having overheating problems, Its had a new Thermostat and the waterpump has been removed and checked and is functioning correctly but it still seems to overheat, It'll sit happily on 90 during idle but after 3-5 minutes of driving it'll overheat and creep upto the 110-130 mark and advise the engine has overheated and to idle the engine. I was wondering if anyone else has had an issue like this and what my next steps should be?
| Newbie Urgent Wiper Washer Fault help |
Posted by: ronseal - 14:th-Aug-2020, 18:34:45 - Forum: Astra-J/GTC Common Problems
- Replies (8)
Firstly hi Everyone
new to this forum so hopeful be able to get some help form you guys as heard some good things...
I have a 2014 Astra J 1.7 Diesel that's just failed its MOT due to wipers not providing water.
both front and back decided to stop so did the usual, blew some air through the pipes and cleaned the nozzles and washer bottle out
wasn't getting a hum from the motor when the stalk was pulled forward or backwards so purchased a new washer pump which solved the rear issue but the front still wasn't working so bought a new stalk from Vauxhall fitted that and no change.
when you push backwards everything works as it should, when you pull forward the wipers sweep as normal but no motor sound or water.
its not the pipes as i swapped round the fittings so pressing backwards sprayed the front and everything was OK
however doesn't seem to want to engage the motor when pulled forward
anyone got any ideas, it doesn't come up with any errors that i can see so very puzzled, have i missed something simple or is this a modual or earthing issue and can it be solved easily.
got a free re-test in 7 days so limited time to fix and this is all it failed on so any help would be much appreciated
over to you guys and girls
| 2016 GTC limited edition questions |
Posted by: SMS19 - 13:th-Aug-2020, 09:05:04 - Forum: Mechanical
- Replies (2)
I have just picked up my 2016 GTC limited edition 1.6CDTI and have a few questions.
Did this model of GTC come from the factory with lower suspension if so how many mm is it dropped by compared to other models?
I have the 20" alloys and feel it sits a little too high but don't want to wreck the ride by lowering it by too much if I decide to lower it. What springs would most people recommend?
Would springs from a VXR fit as it looks to sit the perfect hight?
Another problem I have noticed when looking online for parts most online checkers only show "GTC to 2015" in the drop-down menus and then don't have the 1.6CDTi in the list of vehicles. Do most of the 1.7CDTI parts fit or what's the trick to finding the correct parts?
