j overheating astra 4t 1
Astra J 1.4T Overheating
Hi all looking for advice
My Astra has recently started having overheating problems, Its had a new Thermostat and the waterpump has been removed and checked and is functioning correctly but it still seems to overheat, It'll sit happily on 90 during idle but after 3-5 minutes of driving it'll overheat and creep upto the 110-130 mark and advise the engine has overheated and to idle the engine. I was wondering if anyone else has had an issue like this and what my next steps should be?
Airlock maybe or coolant temperature sensor maybe?
(16:th-Aug-2020, 18:06:55)Jpbroad1970 Wrote: Airlock maybe or coolant temperature sensor maybe?
Coolant Temp Sensor is built into the thermostat from what i can see, Every time I've had to replace coolant I've vacuum bled it afterwards. I'm really picking my brain on what else it could be
UPDATE: After checking the breather/return pipe we've uncovered it had been glued back together (by a previous owner) after being broken and then caused the pipe to block, causing the engine to overheat
  VAUXHALL ASTRA 1.7 CDTI FUEL SENDER UNIT 13272601- FUEL ERRATIC GUAGE BELWO HALF TAN caretaker 3 4,721 21:st-Oct-2024, 18:22:15
  Vxr bumper on 5 door Astra j Sh4rk2007 10 15,102 6:th-Jun-2021, 18:25:04
  New Battery for Astra J 2013 reg 1.7 diesel Galway11 6 8,985 13:th-May-2021, 11:38:55
  Astra j gtc modifications BillyBryan 2 5,529 9:th-May-2021, 17:15:36
Last Post: Spaghetti
  Astra J Fault code reader suggestions Euroshopper 1 5,372 22:nd-Feb-2021, 08:50:12
  Astra j bonnet won't open help Paul in sheppy 2 5,471 17:th-Feb-2021, 13:13:46
Last Post: Paul in sheppy
  Astra J GTC PDC bracket milozic 5 7,139 2:nd-Feb-2021, 09:39:35
  Astra J Rear Bench Seat Clip. MrScottyMan 1 7,155 24:th-Jan-2021, 14:44:22
