buttons fit retro sport and tour
Retro fit sport and tour buttons
Hello all,
I found a guy over here that can install sport and tour button with limited functions. (Steering wheel and accelerator sensitivity, Auto gearbox shift down etc)
However, upon my checkings I do not have the looms that are necessary. While I was waiting for my buttons to arrive I would like complete the loom on hand so if possible can someone (probably rusty Hi rusty Angel ) supply me with the pinout for the BCM and the buttons.
PS I tried gme-infotech portal but its name changed as servicebox even I made necessary registrations I coudn't open the old system, also I never able to find cable data over system :S
Anyways thanks in advance...
Ow I found BCM side over the from
https://www.vxoc.org.uk/forum/attachment.php?aid=1046
If I just get the sport and tour button parts I will be very appricated...
Here you are.
BCM are attached rather than images.
[Image: Tour%20Mode%20and%20Sport%20Mode%20Switc...URC%29.png]
[Image: S108%20Tour%20Mode%20Switch%20%28F45%20or%20URC%29.png]
[Image: S109%20Sport%20Mode%20Switch%20%28F45%20or%20URC%29.png]
.pdf   K9 Body Control Module X1 (RHD).pdf (Size: 97.37 KB / Downloads: 48)
.pdf   K9 Body Control Module X5 (RHD).pdf (Size: 195.66 KB / Downloads: 39)
This is perfecet Rusty thank you very much Smile
Did you manage to get this working, would it work on a 2.0 5 Door Elite with normal suspension?
(17:th-Aug-2020, 11:06:10)Rusty2009 Wrote: Here you are.
Hi Rusty !
I mounted a tesla navigation and had to relocate some buttons like Sport , Tour, ECO and Lane departure warning .
So I ordered some custom buttons for this. I wired them like this (for sport and tour): Pin 1 and 3 momentary button for function activation, Pin 4 and 6 for the function activation indicator lamp . My question is : How should the wire for pin 2 be wired? The one for the backlight dimming control. Also is it correct the way I wired the rest of the wires ?
I would be really grateful for some help.
Cheers!
  Flex ride retro-fit Rusty2009 10 17,149 30:th-Dec-2022, 17:24:04
  Retro Fit Apple Carplay Question ed-b 1 6,707 10:th-Jul-2021, 09:28:30
Last Post: dammfust
  Simple Retro Fit Way for Xenon syscleaner 9 21,913 11:th-Feb-2017, 08:34:22
6 User(s) read this thread:
Qaranc (26:th-Jul-2025, 22:35:40), jas7c5-2008 (11:th-Jan-2026, 13:46:06), opelopc206 (5:th-Aug-2025, 03:14:57), Megature98 (7:th-Feb-2026, 14:29:29), dawik1314 (15:th-Aug-2025, 15:55:11), TonyP (4:th-Nov-2025, 22:03:38)
