DAB retro fit for cars with the CD 400
This is a How for Factory DAB and Integrated FM and Shark Fin Ariel.
for the CD400 with out the Rear Glass Already in Place.
If you have The NAV500 or 600 Go to the How to for The NAV500/600.
So if you have the CD400 Follow Here...
The first thing you are going to have Get is the Tail Gate from a car that has DAB
it will have to be Complete with
DAB retro fit for cars with the cd500 and 600
this is for the NAV500 and 600 that have the FM already in Place
And the Shark Fin on the Roof for the Sat Nav
But do not Have DAB.
If you have the CD400 go to the CD400 DAB how to.
So if you have the NAV500 or 600
And you have the Tabs in Place on the Rear window
then you will find the one for the DAB is a Dummy
just put there in Place to make
USB factory retro fit
...........USB RETRO FIT FOR THE CD 400......
[Image: http://i179.photobucket.com/albums/w301/...6af1b4.jpg]
Yes This can and has been Done but Again this is a Very Hard one to Follow and to Do
And this really is a big job you will be removing everything to do this one
your best bet is to get this Done by Someone who knows How Too
Rusty2009 or Vxmods on Here c
HOW TO FIT AN ANTI DAZZLE REAR VIEW MIRROR.
You will Have to find a Second Hand Auto Dim Mirror on eBay
If you can get the Small Loom that Goes too the Mirror
and the Console in the Headliner with it Also as it is needed.
If not go to your Local Dealer and Order one as you do Need it
you wont Need the Surround as this Can not be Fitted to the Glass
Unless you Replace
POWER FOLD MIRRORS retro fit
This is Guide is for How Ho fit Power Folding Mirrors for the Astra j and GTC.
STEP ONE..............
Is to make two Looms for the Driver Side and the Passenger side Mirrors
The way I got the Pin’s to Add to the Connectors was to Buy a Spare Driver’s Door Loom
And Remove the Pin’s for the Connectors that you need.
I have taken Pictu
Howto:- Fit Vauxhall Mud flaps
[align=center][Image: https://www.vxoc.org.uk/Images/vxoc%20as...x.o.c.jpeg]
Howto:- Fit Vauxhall Mud flaps.
I'm starting at the rear.
So start by taking the wheel off the car.
[Image: https://www.vxoc.org.uk/Images/rusty/How...Rear/0.JPG]
Give the wheel liner and wheel arch a good clean (I then used panel wipe in the outer paint).
Then remove the torx screws outlined
[img]https://www.vxoc.org.uk/Images/rusty/Howto-M
GENERAL AND THINGS TO CHECK.......
This How to is for the Heated Leather Seats
And Electric Lumber Support on the Astra J 5 Door
I have been Told this will Work for the GTC as well.
The first Thing you are Going to do is to Check the Rear Fuse Box
in the Rear Boot and look for a Fuse in Position (21)
a (25 amp) Fuse should be There if so you
VAUXHALL MANUALS FOR DEALER FIT ACCESSORY'S astraj
[align=center]HERE are some useful links
for dealer fit accessories
for the astra j 5 door
Opel Manuals for Dealer Fit Accessories for the Vauxhall Astra J
Rear parking sensors
Front parking sensors
Park Pilot rear
[url=http://www.ifz-be
How-to fit rear lowering springs to a GTC
This is a how-to for fitting rear springs to a GTC the 5dr will be similar
Tools required
Trolley Jack
Qty 2 Axle stands
Locking wheel nut key
19mm socket
21mm Socket
Breaker Bar
Ratchet
Torque Wrench
New lower shock bolt part no. 11610587
Start by loosening off the wheel nuts on both rear wheels using the 19mm socket and locking wheel nut key
Jack up the rear of the car from the centre of the rear axl
Cant fit a vauxhall radio and got no steering controls for connect2?
This ex police astra J is doing my head in, I bought a reset radio off ebay which wouldn't communicate with MDI in the car for some reason so had to send it back, now I started looking at connect2 again and realised I need steering controls for it which I don't have, so yet again im stuck with it and the car is driving me mad, stupid Vauxhall want £500 for a brand new radio fitted, I found someone on here selling one but there 200mile away and still quoting me near 300 for it, anyone any ideas?
