parking assist sensor front
Front parking assist sensor
Hello. From a few months I own Atsar J sportstourer. I have a few problems with the front park assist sensors. Today I have removed the front bumper and my jaw dropped. The previous owner probably has removed the bumper for a respray and he has not connected everything the normal way. From first view in front I thought that there were two front sensors but when I removed the bumper there were four. Two in the middle sprayed black were just hanging into the bumper curve attached to nothing. Now I dont want where those should go as there is no place to for them. Any help and photos if possible would be great so I can fix this par assist. Thank you in advance for the cooperation.
looks like your bumper has been replaced or fixed
you should have 4 sensors in the front bumper two at the front and two at the side
If there aren't any holes for the sensor to fit into it would make me think that he has actually replaced the front bumper and not bothered refitting the factory sensors. There should be holes for the sensors a couple to the left of the number plate and a couple of inches to the right of the number plate and just above the indicators.
as above they must have changed that part for the wrong type
My bumper is like this one http://st.motortrend.com/uploads/sites/5...r-view.jpg but with two holes fro the sensors in it. Cant the be in the lower grill?
If yours is 2012 or below I can only see the bumpers with two sensors at the front. I would have thought though that drilling two extra holes for the 2 spare sensor would be reasonably straight forward.
After a few digs trough the cables I have found this one hanging from one of the cables for the sensors. Anyone knows where this one goes
On the preface model, you have two physical holes in the bumper and the two sensors in the middle are located in the grill. I've screenshot a photo I have of my car and the sensor in the grill. If you need me to get a better pic let me know. That plastic you have may be the bit which clips into the grill, I say may as I'm not sure, but with it saying RH Inner I'd say it's a solid guess
Because I'm feeling especially helpful, here's photos on either side I've just taken
Left hand side (as you look at the car)
Right hand side (as you look at the car)
Excellent. Can I ask for full front picture to see the grill as I dont have those caps that are shown in the last picture, and this makes me think I'm missing some parts
I saw those in some of the pictures I looked at but because they weren't close ups they just looked like fixing screws lol.
I was LOL also. Missing the whole fitting kit for both sides I have only the one thing
I'm being lazy so I've zoomed and screenshot a photo of mine for you. Hopefully it's clear enough.
Perfect. Spoke with the dealer and they found those 4 plastic mounts for me. They were kind a shocked that those are missing
Glad you for it sorted mate.
Sorted nope. Sick. The parts arrived after 12days. But again no luck, the inner could not go anywhere, the outer also. The sensor fits perfectcly in both. Tried almost everything and couldnt fix it to its right place. Dont know as now I have (think at least) all parts but no. If any one has some info on how those should be fited please share
What do you mean couldn't go anywhere?
Those morrons have sent me wrong parts. They have sent me two brackets for the inner mounts, two brackets again for the outer ones(those that are fitted in the bumper and colour coded) they havent sent me the ones that are from the outside of grill. And even then the brackets one that I have pictured above it doesnt seems to fit anywhere in the grill.
They have sent me 16 and 17 which are the inner brackets for all of the sensors. Now I have to find outer ones. But as per them only thise parts appeared for my car by number
The ones on the grills are moulded as part of the grill.
17 & 20 are what you bond to the bumper (a body shop will have the right stuff to bond them in place).
There you go then. You might need a new grill
here's a link for you.
http://www.ebay.co.uk/itm/GENUINE-Vauxha...SwWTRW1GiA
What is the 2nd hole on the left-hand side of the lower front bumper grill? It has a moving part inside (look like a wobbly stick) and not a shiny sensor. There is a similar hole on the right-hand side of the grill but no wobbly stick inside, just an empty hole.
There are two additional holes in the lower front grill. The one on the passenger side as a wobbly stick inside it and the one on the driver's side appears to be empty. What is the wobbly stick? And why is the driver's side hole empty?
I believe you talking about the air temp sensor holes.
The following 1 user says Thank You to Rusty2009 for this post:
  • ericlawrie
(18:th-Jan-2026, 20:24:55)Rusty2009 Wrote: I believe you talking about the air temp sensor holes.
  Car unlocked and front windows half down. Multiskilled 4 7,505 3:rd-Jan-2020, 18:06:58
Last Post: Multiskilled
  Electric Parking Brake andybrody 12 13,106 5:th-Jul-2019, 17:44:36
  Radar Sensor Cabling kebibg 0 5,164 16:th-Apr-2019, 07:27:39
Last Post: kebibg
  Parking Sensor Display Vx-Mad-G 14 23,029 29:th-Mar-2018, 16:49:42
Last Post: zzattack
  front wiper wojtaas_pl 1 5,632 22:nd-Sep-2017, 07:28:07
  Parking sensors Aks72 0 4,248 21:st-May-2017, 00:33:35
Last Post: Aks72
  Washer Motor stopped (front & rear) neilll 3 10,037 6:th-Dec-2016, 14:03:31
Last Post: stigeye
  Locate sensor voltage Rain cosmo black 2 6,226 9:th-Oct-2016, 15:02:44
Last Post: cosmo black
  Rain sensor Kado1111 70 58,728 9:th-Oct-2016, 00:32:21
6 User(s) read this thread:
Rusty2009 (19:th-Jan-2026, 10:05:27), Big Dave2 (19:th-Jan-2026, 11:15:44), husky (3:rd-Apr-2026, 21:49:19), Buashei (4:th-Feb-2026, 11:44:12), dbk2ii (23:rd-Nov-2025, 11:59:17), ericlawrie (19:th-Jan-2026, 15:20:10)
