locate rain sensor voltage
Locate sensor voltage Rain
Hello to all I do not know if you know that our dear astra j has a spy for the automatic wipers that only works on the first astra j.
To me it does not work and now I incocciato I want to make it work ...
So the first thing I put 2 SMD LED in the instrument without connecting them to the instrument ....
So the first thing I try to remove the detrimental wipers and check whether putting the lever of rain sensor if one of the pin generate a fixed voltage to the sensor.
But the only pin that I have noticed signs of life when I set the lever to the first position to activate the rain sensor virtually passes from 10v to 2.70 v when the sensor is active and if I set the sensitivity of the sensor to masimo down to 0.70v.
While everyone else is always + 12v
I have also seen close to 3 pin arriving at the sensor but no dice there is a + 12v fixed a -12V and + 7V ...
Does anyone know how I can help find any tension when the lever is set to rain sensor
If I understand you right you want the LED on IPC to light up when auto wipers are on?
This depends on what IPC you have, i have the LED fitted but won't light up as I have a message pop up when I start the car.
then I Nos interested in the IPC. I want to know where can I connect a led when imposed the lever on prina position to activate the sebsore rain-ons .... can you tell me where I have to feed to do that turn on when active rain sensor?
  Front parking assist sensor SectorOMEGA 23 23,572 19:th-Jan-2026, 04:04:37
  Radar Sensor Cabling kebibg 0 5,168 16:th-Apr-2019, 07:27:39
Last Post: kebibg
  Parking Sensor Display Vx-Mad-G 14 23,029 29:th-Mar-2018, 16:49:42
Last Post: zzattack
  Rain sensor Kado1111 70 58,735 9:th-Oct-2016, 00:32:21
Last Post: cosmo black
