Locate sensor voltage Rain
Hello to all I do not know if you know that our dear astra j has a spy for the automatic wipers that only works on the first astra j.
To me it does not work and now I incocciato I want to make it work ...
So the first thing I put 2 SMD LED in the instrument without connecting them to the instrument ....
So the first thing I try to remove the detrimental wipers and check whether putting the lever of rain sensor if one of the pin generate a fixed voltage to the sensor.
But the only pin that I
Turbo vane position sensors voltage high
Does anyone know anything about this do you think I’ll have to change the sensors or is there away to fix it or things to check thanks in advance
