Rain-x
Can't remember who posted it but I got a spray bottle of rain x from asda for £5, looks like you could get a good 20 uses out of it and it works well!!
Rain mirror shields
So having a look on eBay for the wife's fiesta I came across some rain mirror shields
http://www.ebay.co.uk/ulk/itm/281818471047
I've had a look for the Astra but can't find anything anyone come across them or even used them before?
Rain sensor
astra j edition 2012 models fitted rain sensor Do I Can i
Rain and Light Sensor
Here I'm selling a rain and light sensor for the Astra with loom. It may require some new gel to properly secure it to the screen.
[Image: http://uploads.tapatalk-cdn.com/20160826...fb233d.jpg]
Looking for £30 posted
Rain Sensor/Light Sensor
Hi Guys,
Wonder if anyone can help, I seem to be having what I think is an issue with the light/rain sensor in the Astra J. Not sure if its the sensor thats at fault, something else or not a fault. The issue is with the automatic headlight function, sometimes like today I started the car and it proceeded to put the headlights on even though its clear sunny day and the car is in direct sunlight. Other occasions i've had it when washing the windscreen it would come on and they would stay on for
Locate sensor voltage Rain
Hello to all I do not know if you know that our dear astra j has a spy for the automatic wipers that only works on the first astra j.
To me it does not work and now I incocciato I want to make it work ...
So the first thing I put 2 SMD LED in the instrument without connecting them to the instrument ....
So the first thing I try to remove the detrimental wipers and check whether putting the lever of rain sensor if one of the pin generate a fixed voltage to the sensor.
But the only pin that I
Rain sensor (meriva B)
Don't suppose anyone knows the difference between the round rain sensors, as fitted to corsa's, meriva B's, zafiras and some other vauxhalls,
They have a 2 letter code on them, SA, SB, SC and SD.
On ebay it seems the SD one is for the meriva B,  i know the SC one is for corsa's, as i got one from a corsa at the scrappers,
I've wired it in... power and earth taken from the supply to the auto dipping mirror i fitted a few weeks ago (takne from the relevent pins on the BCM as if it were fa
