week light before esp emoji24 warning service and 1 mot abs
Abs light and service esp warning 1 week before MOT [emoji24]
Hello,
Nightmare scenario 1 week out from MOT ABS light and Service ESP message along with the traction control light have come on.
I have opcom and I tried firstly to clear all faults lights came straight back.
The only portion of the diagnostic code i can see is as follows:
**********************ECU ID STARTS**********************
Source Address: EBCM
Identifier: 0x2B02
Number of stored fault codes: 2
C0110 - Pump Motor Circuit
(00) - Present
C0110 - Pump Motor Circuit - Open
(04) - Present
Would someone be able to point me in the right direction of where to start troubleshooting this?
Thanks in advance for any help received.
Scott
Sent from my Pixel XL using Tapatalk
This may be a start mate.
https://workshop-manuals.com/vauxhall/as...dtc_c0110/
(24:th-Mar-2018, 17:28:27)Rusty2009 Wrote: This may be a start mate.
Cheers appreciate it
Well I had a look at all the connections and reseated the fuses. Cleared all the codes and drove about for two hours and none of the errors have returned. I am not naive enough to think that this is the end of this but if it gets through an MOT then in can get it looked into further when I have time.
Thanks for the help so far...
Hi, I know this is an old thread but here goes. My abs and esp lights came on Friday morning. I brought car to a mechanic who put an obd reader on the car. He told me speed sensor /abs sensor was gone on drivers side rear. I changed the abs sensor and got my mobile mechanic to come out today and clear the fault code. As soon as I started to drive off abs and esp light came on again. Any ideas guys?
I would say abs relucter ring ...the bit the sensor picks up from which I think is built into the rear wheel bearing but not 100% sure. Or it's a wiring fault.
  Rear light power problem phlyer 1 2,357 21:st-Dec-2023, 08:27:49
  HELP PLEASE - Service Vehicle Charging System Vx-Mad-G 24 17,107 14:th-Oct-2020, 08:44:20
  Dpf regen led light Kiel0777 0 3,223 28:th-Jun-2020, 07:49:45
Last Post: Kiel0777
  Corner light make sistem93 2 4,561 17:th-Dec-2019, 19:39:49
Last Post: sistem93
  Eco button light flashing jw021979 6 7,753 9:th-Aug-2019, 21:09:48
Last Post: jw021979
  Rear light out but works again with headlights Willcbrbikeboy 6 5,126 14:th-Jan-2019, 09:43:44
Last Post: vocky
  ESC and Engine Light Acond 2 4,312 16:th-Nov-2018, 19:32:48
  Service power steering warning light. R4hulb 4 13,482 23:rd-Mar-2018, 13:01:58
Last Post: R4hulb
  Service ESP Help! bradleyy_ev 6 24,307 17:th-Feb-2018, 13:06:09
Last Post: bradleyy_ev
  Boot gate light GTC13LFP 1 3,123 16:th-Nov-2017, 21:26:22
Last Post: Iaintruten
greg848484 (1:st-Jul-2023, 06:23:08)
