how too AMBIENT LIGHT AROUND THE GEAR GATOR
This is a how to for the ambient LED light
that goes around the Gear Gator using the Factory LED.
first step........
Is to Remove the Stereo Surround trim
for removal follow this.
How-to remove the head unit
[img]http://www.vxoc.org.
How To remove the front courtesy light
[Image: https://www.vxoc.org.uk/Images/rusty/pos...ight/1.JPG]
1. remove the trim from around the light
[img]http://www.vxoc.org.uk/Images/rusty/post%20images/How-To%20front%20c
security light
LOOK AT POST 29 FOR THE HOW TO.........
i am just in the process of retro fitting this
[Image: http://i179.photobucket.com/albums/w301/...7a7020.jpg]
[Image: http://i179.photobucket.com/albums/w301/...17d161.jpg]
i have had to add power and ground
and a switch to turn it on and off
light up door sill protectors
Found these not sure TBH.
Epb orange light
Hey guys. Been having the orange lighting/spanner light coming on for a few seconds when pressing and releasing the footbrake. Now for the first time car wouldn't release the handbrake unless I push the epb button. This was starting car from standing still for about an hour. But it also started then died straight away as if it stalled but without any notice. Dropped kids to disco engine off for a few minutes and it released normal. Could this be the clutch switch? If I tell vx the light been on
light scratches in windshield
ok so i always hand clean my car
and when i drove in the sun i noticed scratches (vercial and horizontal)
How can i prevent this in the future?
and can i get them out?
btw, i used a water beam last time and not a sponge.
i dried it with a soft thin towel
How-to led reverse light
THIS IS A HOW TO AND REVIEW OF THE SMD LED REVERSE LIGHT BULB
FOR THE ASTRA J 5 DOOR.
So here are the SMD LED Bulb
that is a Direct Replacement for the Standard Bulb
it looks very well made and it is also Really Bright
and also Error Free.
[Image: http://i179.photobucket.com/albums/w301/...0c8aca.jpg]
[img]http://i179.photobucket.com/album
Vanity light bulbs
So I tough i would try buying some cheap bulbs for the reading lights,
These ones are cheap, a perfect fit, very bright, no errors, perfect
4x 30mm 31mm NUMBER PLATE INTERIOR LIGHT FESTOON BULB 6 LED XENON WHITE 269 c5w | eBay
Fog light bulbs
can anyone recommend some white fog light bulbs?
Brake Assist Warning Light
I have a 2010 Astra SRI and the brake assist (BAS) has just starrted showing a warning
I haent found much information from googling.
Im hoping its a simple thing like the sensor on the brake servo[ATTACH=CONFIG]220[/ATTACH]
Any advice?
