light gate boot
Boot gate light
I recently brought an astra gtc 2013 and I have noticed the red light on the boot door on the passenger side of the boot gate only lights up when I open the boot and not when I turn on the lights. Is this normal or do I have a defective light?
will appreciate your help as this is my 1st car and i would like it to be running all in order.
Many thanks.
Luis.
Hi there did you get this issue solved? If not send a photo so I can see what light your taking about, it could be anything from a bad earth to a lose connection etc is it consistent with opening the boot or does it flicker?
  Rear light power problem phlyer 1 5,039 21:st-Dec-2023, 08:27:49
  Abs light and service esp warning 1 week before MOT [emoji24] Sc0tty05 5 16,142 24:th-Nov-2020, 18:25:28
  Dpf regen led light Kiel0777 0 5,002 28:th-Jun-2020, 07:49:45
Last Post: Kiel0777
  Corner light make sistem93 2 6,737 17:th-Dec-2019, 19:39:49
Last Post: sistem93
  Eco button light flashing jw021979 6 11,784 9:th-Aug-2019, 21:09:48
Last Post: jw021979
  Rear light out but works again with headlights Willcbrbikeboy 6 9,804 14:th-Jan-2019, 09:43:44
Last Post: vocky
  ESC and Engine Light Acond 2 7,575 16:th-Nov-2018, 19:32:48
  Service power steering warning light. R4hulb 4 23,198 23:rd-Mar-2018, 13:01:58
Last Post: R4hulb
  Switcheed / Ignition positive feed required in boot area IanMcD 8 15,405 11:th-Dec-2017, 04:55:01
Last Post: budfurn
  Problem reverse light Keith2017 6 18,129 1:st-Apr-2017, 17:55:16
Last Post: Keith2017
