problem light reverse
Problem reverse light
Hi hope someone van help when i put my car into reverse the reverse bulb dont go on anymore checked the bulb but thats nog the problem also checked switch on gearbox thats ok to only thing left is the fuse but cant find location off it in the manual
http://www.autogenius.info/category/vaux...-vauxhall/
It's fuse 19 in glove-box, but irrc that also controls other lights.
If It's not the fuse I would try cleaning the contacts on the bulb and holder.
If that doesn't work it could be a broken wire an bad earth point or even the BCM failing to send the signal.
The ground point for that is located behind the trim in the rear on passenger side drop the flap down you should be able to find it.
(30:th-Mar-2017, 07:30:06)stigeye Wrote: http://www.autogenius.info/category/vaux...-vauxhall/
We have that on this very forum
https://www.vxoc.org.uk/forum/Thread-Fuses
Hello thx for your answer hope not the bcm will look at everything andere post if its fixt or nog thx
(30:th-Mar-2017, 07:31:11)Rusty2009 Wrote: It's fuse 19 in glove-box, but irrc that also controls other lights.
Just did everything you wrote but that nog helped also fuse is ok i just ordered new switch to try out not cost that much so hopefully everything works well again
just installed new switch now the reverse licht burn nut after second its out again
  Rear light power problem phlyer 1 5,231 21:st-Dec-2023, 08:27:49
  Meriva B GID problem edomali 0 5,078 28:th-Apr-2021, 11:47:03
Last Post: edomali
  CD400 power problem bigles 6 8,213 22:nd-Dec-2020, 05:56:33
Last Post: bigles
  Abs light and service esp warning 1 week before MOT [emoji24] Sc0tty05 5 16,572 24:th-Nov-2020, 18:25:28
  Dpf regen led light Kiel0777 0 5,131 28:th-Jun-2020, 07:49:45
Last Post: Kiel0777
  IPC upgrade problem coabacje 0 5,627 11:th-Jan-2020, 18:58:54
Last Post: coabacje
  Corner light make sistem93 2 6,924 17:th-Dec-2019, 19:39:49
Last Post: sistem93
  Eco button light flashing jw021979 6 12,245 9:th-Aug-2019, 21:09:48
Last Post: jw021979
  Rear light out but works again with headlights Willcbrbikeboy 6 10,221 14:th-Jan-2019, 09:43:44
Last Post: vocky
  ESC and Engine Light Acond 2 7,811 16:th-Nov-2018, 19:32:48
