Pain in the assignment problem
I purchased a 61 plate 2.0td with 26000 on the clock. Knew it was cat d repaired but drives like a dream. Everything is perfect apart from one thing!
When driving the 'service vehicle soon light comes on' when this happens the start stop doesn't work, cruise control doesn't work and handbrake auto release doesn't work! When the light
ongoing problem UPDATE
So I've still got the ongoing problem with the SVS light coming on. It's been in vx the last 2 days and they think they have found the problem, apparently pin 24 is broken on the esc connector, this is apparently causing my problems with the clutch switch! It's costing £288 as hey say this must have been caused when the repair was done to my car when it was in its accident. They also said there is now no error codes, does this sound viable? I'm just worried incase the light comes back on, what
Problem with park assist
So recently i have noticed when i press the park assist button it no longer displays on dash "park assist on" but if i turn it off it will say the off...
Anyone any idea how to solve this please?
We today have had battery off for other things today and that hasnt reset issue.
Key problem on Astra.
My key on a 2011 Astra has broken. The blade silver part that rotates and holds the blade in place has broken.
Is there a way to open the key up to replace this part?
Occasional problem turning on
I have this problem, very rarely, where when I turn on the car, the engine doesnt seem to bite correctly.
It tries to go but then just seems to tick over a few times it eventually does start but sounds likes its not going to for a few seconds.
Like i say its very rare it happens, and all i can narrow it down to it not turning the key enough, Im not expecing many replies as i know its an awful description but thought I'd just put it out there.
Astra is a 1.6 petrol energy
My new Gtc problem already
Hey guys sorry for the delay with the pics it's been a long weekend and finally
Parked the car up and stayed in doors lol
I picked up my gtc on Friday and after a long wait at vauxhall everything was good to go
I've literally been over the moon with the car and even happier now I've finally got it.
As some of you know I was looking at getting some tint just couldn't decide how dark to go and if
I should do the fronts and the rears or just the rears so Once I left vauxhall I
got quite a problem
went to change the indicator bulbs, the metal clip bit came off alltogether, realised i had the wrong bulb, so couldnt change them, couldnt get the metal clip back on, is there an easy way for access to it, like taking the arch liner out, or am i going to have to take the bumper off, also what bulbs do actually fit there?
fan blow problem
Hi all
I am having problems with the blow not coming out the screen vents.
On changing the pollen filter check the selector as it's climate control, check the motor and they work just that the selector does not turn all the way to the screen post ion with out help.
have oiled it and helped buy still sticks, any idea how to free it up or any 1 had this issue before maybe ?
Simon
Problem today with the server
There are technical difficulties today 17/03/2015 effecting the forum we hope to resolve this issue tonight tapatalk is still operating correctly
Help-2012 Astra J S model rear window demister button problem
I have a 2012 astra and the light does not come on on the rear window demister button. I only baught the car 2nd hand.
Its the button with the white box and the wavy lines through it.
Can anyone point me in the direction of the possible problem
