How to Install a Reverse Camera in an Astra J with Navi 900
Here is an installation guide for fitting a reverse camera to an Astra J with Navi 900. If you have the DVD 800, the installation is similar but you will probably need a RGB interface box instead of the GVIF interface used in the Navi 900.  I presume Navi 600 is the same as Navi 900 as far as reverse camera's go but I cant be sure abou
How-to led reverse light
THIS IS A HOW TO AND REVIEW OF THE SMD LED REVERSE LIGHT BULB
FOR THE ASTRA J 5 DOOR.
So here are the SMD LED Bulb
that is a Direct Replacement for the Standard Bulb
it looks very well made and it is also Really Bright
and also Error Free.
[Image: http://i179.photobucket.com/albums/w301/...0c8aca.jpg]
[img]http://i179.photobucket.com/album
After market Reverse sensors
Hey guys
Anyone know I which are the best type of aftermarket reverse sensors are that can be fit by a garage? It's something I'm thinking of getting in the future and see a lot of garages offering it as a service but don't wanna pay them like £150 and have them fit cheap rubbish ones, would rather buy my own and pay them to fit them.
How To: Fit aftermarket Reverse Sensors
Introduction:
Here is my tutorial on installing a set of rear aftermarket parking sensors. You’ll want to start off by following my tutorial below to remove the black interior boot trim before you do anything else. Once this has been done then you can start with the installation an
Rear brake/reverse light
Anyone have any red reverse/brake lights? I have found the one I need on ebay for £40 (£20 for the tinted one) but I'm after the red none tinted version to replace my damaged one and I'll tint it myself with the spray.
Reverse bulb upgrade
Hi so ive upgraded my tail lights to LED works fine tail light are not on the Canbus however the reverse bulb is and its causing an error does anyone know if there are any plug and play resistor kits for this part of the lighting system as it has a different connector and the bulb is the offset type i cannot see any. I dont want to be cutting wiring and i am using a canbus error but its not pulling enough power clearly thanks.
Reverse Camera wiring
Hey all
I've ordered a reverse camera to go wit my new head unit (when it arrives) and it requires power from the reverse light itself...Now I already have my reverse parking sensors wired into this reverse power light...So would it cause too much power draw to have the reverse camera wired into this same power cable?
How to Install Android Head Unit + Wireless Reverse Camera
Welcome to my tutorial on installing the Android M072 Aftermarket Head Unit (this tutorial could probably be used for other head units too) and wireless reverse camera. So here’s a pic of everything I ordered and needed for this mod:
Head Unit Itself:
So you’ll want to follow the tutorial that @rusy2009 put up on how to remove the head unit:
[url=https://www.vxoc.org.uk/forum/Thread-How-to-remove-the-head-unit-from-the-car-includes-Screen-removal]https://www.vxoc.org.uk/forum/Thr
Reverse camera video interface
No longer required had this on my VXR and was very good
Multi media video interface you can have reverse camera or any other video source plugged in and viewed on Navi 600/650/900/950 screen. Also comes with bumper mounted reverse camera
[Image: http://img.photobucket.com/albums/v281/c...mhlfbk.jpg]
Looking for £120 collected or £130 posted.
Multimedia interface, reverse camera, navi 600, insignia, astra j.
THIS HOW TO IS FOR THE MULTIMEDIA VIDEO INTERFACE BOX FOR THE NAVI 600/900 ON THE ASTRA J AND THE INSIGNIA
THIS WILL GIVE YOU THE REVERSE CAMERA FUNCTIONALITY ON THE FACTORY NAV DISPLAY.
[align=center]The box can be found at xcarlink, the link is here.
 https://www.google.co.uk/url?sa=t&rct=j&...rl=http%3A%
