light flashing button eco
Eco button light flashing
I have searched high and low for an answer to this but cant find anything.
I have a 2013 2.0 CDTi S/S. Ever since I fitted my Android Headunit, about 18 months ago), the Eco button on the dashboard is constantly flashing (until I turn it off). I have changed the button but its still the same. Wiring all appears OK. Any ideas why this may be happening. Stop/ Start hasn't worked for about 6 months, not sure why as battery seems OK and I don't have any error messages stored.
That's an odd one the radio shouldn't effect it, I'm guessing your referring to the tell-tell light rather than the button light?
S/S has so many factors at play, do you just do town work or do you do motorway driving etc too?
I do various types of driving from driving around Bournemouth in town to driving country road's and dual carriageways. I don't have problems with dpf and no fault codes. I suspect it's my battery but it starts OK with the key in the morning, just the stop start doesn't work anymore. As far as the eco buttons flashing, I may have to pull the headunit out to check more of the wiring
We have mostly likely past each-other at some-point driving round Bournemouth then.
Yes I would pop the Android out and fit the factory and see what happens with the light (although like I said the radio shouldn't effect it). if you want to pop by I can run a scan on the car and check for any error codes stored in any of modules on the car.
(25:th-Feb-2019, 08:13:52)Rusty2009 Wrote: We have mostly likely past each-other at some-point driving round Bournemouth then.
I have had the Android unit out today and checked the connections a re all OK which they appear to be. I turned on the car with no headunit connected and the Eco button still flashes. I may have to take you up on the offer of scanning for codes at some point although I have also considered fitting leather seats so would be in need of your services for that as well.
Not a problem I'm just off Holdenhurst Road.
Got this all sorted now. Put a new battery in yesterday. Stop start now works and the eco button has stopped flashing.
  Rear light power problem phlyer 1 5,265 21:st-Dec-2023, 08:27:49
  Abs light and service esp warning 1 week before MOT [emoji24] Sc0tty05 5 16,644 24:th-Nov-2020, 18:25:28
  Dpf regen led light Kiel0777 0 5,158 28:th-Jun-2020, 07:49:45
Last Post: Kiel0777
  Corner light make sistem93 2 6,937 17:th-Dec-2019, 19:39:49
Last Post: sistem93
  Rear light out but works again with headlights Willcbrbikeboy 6 10,254 14:th-Jan-2019, 09:43:44
Last Post: vocky
  ESC and Engine Light Acond 2 7,850 16:th-Nov-2018, 19:32:48
  ECO button connector diagram (start/stop) aurega 1 11,270 4:th-Nov-2018, 15:06:37
  BCM pinouts - ECO button wojtaas_pl 0 6,334 3:rd-Sep-2018, 11:22:15
Last Post: wojtaas_pl
  Service power steering warning light. R4hulb 4 23,585 23:rd-Mar-2018, 13:01:58
Last Post: R4hulb
  Boot gate light GTC13LFP 1 5,018 16:th-Nov-2017, 21:26:22
Last Post: Iaintruten
