light esc engine and
ESC and Engine Light
Hello all
What happened this morning was that during acceleration the car (Astra J 1.6) behaved like misfiring, acceleration was slow and car was "Jerking" then Electronic Stabilization Control lit got on and Engine Light started to blink. After acceleration the car was running normally and idling normally both light went off.  Next time when accelerating same happened again I do not know yet which lit came first on and which one first off - can check later. No codes found in engine section. What could this be?
Quite common is the coil packs on the petrol's.
In terms of error code what are you using to read the codes as alot of code readers are useless.
I had a similar problem with my 1.6 manual Astra, I changed the spark plugs which cured the fault.
but as rusty says the coil packs are a known weak spot.
  Rear light power problem phlyer 1 5,038 21:st-Dec-2023, 08:27:49
  Abs light and service esp warning 1 week before MOT [emoji24] Sc0tty05 5 16,137 24:th-Nov-2020, 18:25:28
  Dpf regen led light Kiel0777 0 5,002 28:th-Jun-2020, 07:49:45
Last Post: Kiel0777
  Corner light make sistem93 2 6,736 17:th-Dec-2019, 19:39:49
Last Post: sistem93
  Eco button light flashing jw021979 6 11,784 9:th-Aug-2019, 21:09:48
Last Post: jw021979
  Rear light out but works again with headlights Willcbrbikeboy 6 9,804 14:th-Jan-2019, 09:43:44
Last Post: vocky
  Service power steering warning light. R4hulb 4 23,198 23:rd-Mar-2018, 13:01:58
Last Post: R4hulb
  Boot gate light GTC13LFP 1 4,841 16:th-Nov-2017, 21:26:22
Last Post: Iaintruten
  Problem reverse light Keith2017 6 18,128 1:st-Apr-2017, 17:55:16
Last Post: Keith2017
  Green Auto Wiper Light DaPa 12 14,390 13:th-Nov-2016, 13:20:42
