Engine and Gearbox Combinations
[TABLE=Engine and Gearbox Combinations]
[TR]
[TD]PETROL ENGINES[/TD]
[TD]ENGINE CODES[/TD]
[TD]ENGINE BUILD CODE[/TD]
[TD]GEAR BOX[/TD]
[TD]BHP[/TD]
[TD]MODEL[/TD]
[/TR]
[TR]
[TD]1.4 VVT[/TD]
[TD]A14XER[/TD]
[TD]LDD[/TD]
[TD]F17WR[/TD]
[TD]100 BHP[/TD]
[TD]J, ESTATE[/TD]
[/TR]
[TR]
[TD]1,4 VVT TURBO[/TD]
[TD]A14NET[/TD]
[TD]LUJ[/TD]
engine problems
there have been a few issues with water pumps
and other related engine issues
DPF regain problems etc
so if you have had or are having engine issues post here.
Engine Control Module
K20 Engine Control Module X1 (2H0)
[Image: http://www.vxoc.org.uk/Images/vxoc%20ast...0(2HO).png]
[TABLE=]
[TR]
[TD]
Connector Part Information
Harness Type: Engine
OEM Connector: PPI0001001
Service Connector: Pending
Description: 56-Way F (BK)
[/TD]
[/TR]
[TR]
[TD]
[b]Term
Noise from engine
Since driving the car today I have started to hear a noise from the engine that haven't heard before. When I accelerate in 2nd and 3rd gear it's sounds like a hair dryer. It's not loud but can notice it. Any ideas? Could it be anything to do with turbo?
Additives for Diesel engine ?
[FONT=Arial]Hey guys, I have been wondering about additives, I know its a controversial subject but I would like to know your opinion on this subject.
First, I have an Opel Astra sports tourer 2011 1.7L 81kw Diesel break. I use once er month premium diesel that has additives in it, the difference I felt over the regular diesel is slightly better response of the engine, but that's it.
Second, of what I red is that there is 2 types of additives. Oil additives & Diesel/petrol additives. bot
Engine compression 1.3 DTE
Is there anyone who knows if i can watch the engine compression with op-com?
If yes,in which menu?
What's the level for each cylinder in a car without problems...?
Engine Rattling
Hey All,
Just noticed an issue which started this morning and it was 3 days after vauxhall had my car in the garage for a check up.
Basically when I put my foot down at low revs I'm 3rd or 4th gear I can hear a metal rattling noise from the engine bay. It almost sounds like marbles rattling together or something.
Anyone heard of anything like this?
Engine sounds funny...... Or not
https://vimeo.com/126470389
Engine seems to have a weird clicking sound. Is that normal?
Engine bolt covers
Is it possible to buy new bolts that hold the engine cover on? Some of mine are rusty as hell. Had a quick look online and can't seem to find much
Engine cover bolts that should be.
Astra J 1.7 engine chirping and pressure
Astra J 1.7CDTi exclusiv 2010
So I have been letting my issue develop and I still don't hav a clue what the causes are.
No:1, chirping/squeal from engine, does it on idle and now does it when Reving the engine, I'm pretty sure it's not the aux belt because this sounds more at the back of the engine. Once cured by replacing fuel filter but hasn't worked this time.
No:2, engine breathing really hard for no reason what's so ever, has anyone had this problem before? Other minor things that co
