wiper light auto green
Green Auto Wiper Light
On the odd occasion before I start the car a green Auto Wiper Light comes on in the speedo towards the top.
Car is a 1.6 vvt Exclusiv.
Any ideas?
Regards.
I take it you don't have auto wipers?
Have you got a photo?
(25:th-Feb-2016, 14:21:25)bhalay207 Wrote: I take it you don't have auto wipers?
I don't believe the car has auto wipers, being the base model I assumed it did not.
Unfortunately it only appears for a split second on the dash.
Does it lighting up mean there is a problem with auto wipers?
Regards.
here is an image of the light I refer to, it is the one circled,  it lights up green on my dash.
[img][Image: 2elcnsm.jpg][/img]
do you have the auto wipers in reverse option
i have never seen that light up it could be a fault as you say
(25:th-Feb-2016, 16:09:58)tucpal Wrote: do you have the auto wipers in reverse option
How do you check this?
It's on every set of clock even if you don't have lights and wipers it can light up when the car does checks.
(25:th-Feb-2016, 17:18:42)Rusty2009 Wrote: It's on every set of clock even if you don't have lights and wipers it can light up when the car does checks.
I been wondering why does it check the auto wipers and light up on times when they are not fitted?
Just curious or is there a potential problem?
Don't quote me on this but I would have thought that you would have to have auto lights in order to have auto wipers, or should I say that they come together as part of the sight and light pack, so if you haven't got auto lights then you won't have auto wipers... crawls back in bunker to escape the shrapnel lol.
Quite right come as a pack.
One IPC fits many models with different options fitted.
(11:th-Nov-2016, 21:43:43)Rusty2009 Wrote: Quite right come as a pack.
So, back to my original question,  if either auto lights or wipers are NOT fitted why does it do the checks,  or is there a potential problem?
have you noticed whether or not the rear wiper moves while the light is on. If the light turns off after a few seconds I wouldn't worry about it as it will likely be the circuit being checked by the control unit
Every car runs through a check at start-up hence the needle sweep and every light on the dash lighting it, It's normal and nothing to worry about.
  Rear light power problem phlyer 1 5,265 21:st-Dec-2023, 08:27:49
  Abs light and service esp warning 1 week before MOT [emoji24] Sc0tty05 5 16,644 24:th-Nov-2020, 18:25:28
  Dpf regen led light Kiel0777 0 5,158 28:th-Jun-2020, 07:49:45
Last Post: Kiel0777
  Corner light make sistem93 2 6,937 17:th-Dec-2019, 19:39:49
Last Post: sistem93
  Eco button light flashing jw021979 6 12,350 9:th-Aug-2019, 21:09:48
Last Post: jw021979
  Rear light out but works again with headlights Willcbrbikeboy 6 10,254 14:th-Jan-2019, 09:43:44
Last Post: vocky
  ESC and Engine Light Acond 2 7,850 16:th-Nov-2018, 19:32:48
  Service power steering warning light. R4hulb 4 23,585 23:rd-Mar-2018, 13:01:58
Last Post: R4hulb
  Boot gate light GTC13LFP 1 5,018 16:th-Nov-2017, 21:26:22
Last Post: Iaintruten
  front wiper wojtaas_pl 1 5,672 22:nd-Sep-2017, 07:28:07
