Wiper fluid and coolant bottle sensors
Hi All
So I've finally got my new IPC working but wasn't able to disable the warning messages about the low wiper fluid and the low coolant levels. I can't afford to fit the bottles which have the sensors and have read and have been told that I can just bridge some connectors to stop them from appearing...what exactly does this mean and how would I do it?
Also would doing this disable the coolant temp that I see in the display or is this something else?
Retrofit Coolant and Wiper Fluid Sensors
Hi All
Just looking into the sensors I would need to retrofit in order to get the wiper fluid and coolant sensors working as I'm thinking I'd probably get some use out of this so it makes sense to use it rather than have those warnings removed all together. Would be a project for when I have more money but wondering if the following sensors are the ones I need?
13195945 - Washer fluid
13276326 - Coolant
Also do these just sit between the pipes and the actual tanks themselves or ar
Front wiper nightmare
Hi guys,
I'm having an absolute nightmare trying to source replacement wipers for my 60 plate Astra J.
I've had three sets so far, all A585S Bosch Aerotwins.
They have clips as per below, not what my current Bosch wipers have.
[Image: http://i1279.photobucket.com/albums/y527...wxtoyt.jpg]
[URL=http://s1279.photobucket.
Wiper blade size
Anyone know the size of all 3 wiper blades? 2012 1.7 Sri
Green Auto Wiper Light
On the odd occasion before I start the car a green Auto Wiper Light comes on in the speedo towards the top.
Car is a 1.6 vvt Exclusiv.
Any ideas?
Regards.
Rear wiper removal
Hi guys!
I know not everyone likes this mod but has anyone removed their rear wiper and is it easy to do?
De-wiper rear windscreen
Hi, I thought I remembered a how to for the de-wiper. Does anyone have the link or know of a how to to do it please?
Astra gtc wiper and start stop not working
I have a 2012 astra gtc with 27000 miles. My service light is on however i do not need one as it has just been serviced however when the light is on my start stop wont work it just doesn't do it and my wipers will only work on the last highest settings thats it (my back one works fine) however the light in the past has turned off for the odd minute or 2 and everything works fine then but it comes back and they don't work again. I was wondering if anyone knew a solution or what the problem is. Th
Turn Signals and Wiper Stalk Switch
Hi Guys,
So my switches to turn on/off the turn signal and the wiper stalk make a cery flimsy noise when I put them on/off.
The one for the wiper is the worse... as if something is broken.
Is there anything that I can do?
Enviado do meu SM-G935F através de Tapatalk
front wiper
I'm looking for an electrical scheme of front wiper. Espesially a conector of wiper mechanism.
Can anyone help me?
Is some difference for astra j and GTC in front wiper?
