Flexi Floor for the boot on a GTC.
Wouldn't mind retro fitting Flexi floor in to the GTC.
John
What's in your boot
I'm looking at making a kit that's always kept in the boot.....
De icer
Scraper
First aid kit
Blanket
Gloves
Any other suggestions
FREE: LEDs for Boot/Glove Box
Don't suppose anyone wants a free pack of these bulbs do they? I bought a bunch of them as I was going to use them for the interior lights but they are too big...so can only be used for the boot light and glove box light. I used a few but have some left.
Photo is attached for reference.
[ATTACH]505[/ATTACH]
How-to Extra boot light
How-to Extra Boot light.
Ok so first of all you need to feel along the top of the side trim, you will fell there is plastic behind it but as you move along you will feel there is a bit you can push in.
[Image: https://www.vxoc.org.uk/Images/rusty/How...ight/1.JPG]
Once you found that area you can start to cut (DO NOT CUT IT ALL WAY) do a
How To: Boot Door Panel
Hey All
This is just a quick how to for removing the black trim which is inside the boot door (the bit which has the grab handles for closing the boot from the inside).
So to begin with there are 2 x 7MM bolts which hold the lid firmly in place to the frame of the boot itself, you want to remove these first. There are located within the internal grab handles (one on each side).
[color=#ff3333]Photo is of the hole where one of the bolts was removed from (will get a better photo soon). Ther
Clips/Screws in boot area.
So today I eventually got round to taking off most of the side in the boot area to move the buzzer for my parking sensors. The guy who fitted them thought it would be good to stick it on the outside by the rear window on the nearside... apart from the fact you could see it and it ruined the nice look of the interior it was deafening my son when I reversed!
Anyway that's resolved and now resides tucked inside with the wiring etc. on the nearside.
But when I took everything out I found these in
Boot Light
I'm after a spare boot light, the actual casing that is and not the bulb. Can't find a spare online anywhere unless someone has a part number?
Boot Unlock Option
So vx updated all my system the other day and now for some reason when I turn off the car and get out (end of the day when I get home or when I get to the office) the boot remains locked... It never used to work like that, anyone know if there's an option on the car that I need to enable or disable to get it back like it was?
Ta
Remote Boot Opening
Hey,
Does anyone have the remote boot opening feature on their J? Wondering if it even exists as I've never seen anyone with it.
Ta
Super Bright Boot Lights
Welcome to my tutorial on how to fit VERY bright LED panels to the boot compartment.
You have two choices here…either simply replace the ONE factory unit that’s already in place…or add some additional wiring to the factory wiring, run it through to the other side and cut another hole so you can then have TWO of these LED strips installed. If you’re wanting TWO boot lights then follow this tutorial first then come ba
