Micky G - Replies:
Esp,Abs lights
Hi , new on here and wondered if any one has come across the same problem I am having.I have a 2014 GTC 2.0Cdti
With just under 40.000 miles .The other day I turned on the ignition and the ESP service & ABS lights have come on and are on permantley .I phoned my local vx dealer as the car is in warranty and they said they want £80.00 to do a diagnostic and fits found to be a warranty issue I would not have to pay.I cannot justify where they get these figures from so I had a mate look at it and
p38 - Replies:
esp and rpm dial
Hi whilst driving along my esp light came on and my rpm dial went to zero but the car would still drive and rev the rpm dial came back to normal any suggestions of what it could be, i have a 1.6 astra 2010 auto.
Service ESP issue
I have service ESP message showing on the dashboard along with the ABS symbol and car with 2 lines underneath symbol. Borrowed and connected a Bosch KTS 200 diagnostic tool to it and it showed up as error code C0040 Wheel Speed sensor front right malfunction. Bought a new front sensor and fitted quite easily myself but I am no expert with the diagnostic tool. I think I cleared the error memory as the lights and ESP warning message went off but as soon as I gave the KTS 200 back the wa
Service ESP/battery draining
Hi people, I have astra j (62 plate, 5 door 1.7 diesel)
Just wondering if other people have encountered 'service esp' issues or had problems where the car battery is draining and not able to start.
I hard wired some footwell lights in using 12V port on astra J, this isn't a new thing I just replaced the old ones as they broke. Since then issues with car.
Local dealership have it now and at first they called me saying everything was fine and no faults but when they tried to take it off
Service ESP Help!
Hi all!
Looking for some advice. Driving home earlier and at about 40mph I jad "Service ESP" flash up on the trip display- additonal to this the TC light and ABS warning lights both showed in the gauges!
Does anybody have any idea what this could be?
Cheers folks
Sent from my SM-A310F using Tapatalk
Abs light and service esp warning 1 week before MOT [emoji24]
Hello,
Nightmare scenario 1 week out from MOT ABS light and Service ESP message along with the traction control light have come on.
I have opcom and I tried firstly to clear all faults lights came straight back.
The only portion of the diagnostic code i can see is as follows:
**********************ECU ID STARTS**********************
Source Address: EBCM
Identifier: 0x2B02
Number of stored fault codes: 2
C0110 - Pump Motor Circuit
(00) - Present
mpotsb - Replies:
ESP service message, erratic fuel range figures on trip computer
Dear All,
I have a couple of very recent issues with my 63 plate GTC 1.4 t and wonder if anyone can give me some advice.
One relates to the ABS warning light and traction control light illuminating on the dashboard together with an ESP service warning message on the trip computer. I think this might be a sensor issue somewhere.
The vehicle is running ok (ie no misfires, slightly slow pulling away like in a very slight limp mode when it gets to 2000 revs).
Is this an easy fix or somet
AstraRT - Replies:
'Service ESP' HELP
Hi Guys,
I was wondering if anyone has had a similar situation or know anything that could help with my 1.4 petrol 2013 Astra GTC.
recently I had the Service ESP message come up on the dash and took it to the local friend to be read.
The following codes came up:
U0125-00
C0196-71
He isn't sure what the problem may be and I don't want to take it to the garage and they scam me an extortionate amount to fix.
My high beam '3rd' brake light also stopped working around the same time.
Steering wheel angle, esp, power Steering
I would love some help
I have an Opel Astra J 2011 hatchback 1.6 (85kw/115hp), 160,000 km (99,419 mile)
9 months ago my steering wheel was replaced because the horn did not work , after a month or two the ESC (esp) light in my vehicle came on and recently the steering wheel light also came on.
a months and a half ago I put the vehicle in an Opel authorized garage, after a brief inspection
I was told it was a malfunction in the steering wheel sensor, I asked them to replace cos
