Esp,Abs lights
Hi , new on here and wondered if any one has come across the same problem I am having.I have a 2014 GTC 2.0Cdti
With just under 40.000 miles .The other day I turned on the ignition and the ESP service & ABS lights have come on and are on permantley .I phoned my local vx dealer as the car is in warranty and they said they want £80.00 to do a diagnostic and fits found to be a warranty issue I would not have to pay.I cannot justify where they get these figures from so I had a mate look at it and
abs fault
hi all here we go again
i have a esp service now light on with fault code C0045-5a rh wheel speed sensor circuit- not plausible
i have change the wheel sensor as it was my first choice and still no luck as when you first pull away light goes out then hitting about 20mph light is back on which is correct so after some reading it seems it could be the encoding ring at fault which i feel is a poor design as its built into the wheel bearing
has anybody got any ideas as what next to look at
Abs light and service esp warning 1 week before MOT [emoji24]
Hello,
Nightmare scenario 1 week out from MOT ABS light and Service ESP message along with the traction control light have come on.
I have opcom and I tried firstly to clear all faults lights came straight back.
The only portion of the diagnostic code i can see is as follows:
**********************ECU ID STARTS**********************
Source Address: EBCM
Identifier: 0x2B02
Number of stored fault codes: 2
C0110 - Pump Motor Circuit
(00) - Present
ABS sensor/ fault codes
Had service ESP warning light come on, the TC light and ABS light came on.
I've had the codes read, one was drivers side front ABS wheel speed sensor and the other was for ABS pump.
Got both cleared and esp warning came back on straight away from leaving the garage, I have changed the sensor now and had 4 hours of warning light free driving today [Image: https://www.vxoc.org.uk/forum/images/icons/thumbsup.png].
However the ESP warning has come back on, I've not had it back to have the
ABS Ring?
been looking for a replacement ABS ring for my GTC but can't find a sniff of one anywhere.
any places sell them?
Cheers,
Will
StabiliTrak/ABS Issue
Greetings everyone,
I recently started getting random dashscreen warning lights of StabiliTrak and ABS.
While it does that it is like the steering wheel and the wheels are locked and not able to turn.
The error I get when I run diagnostics is High Voltage consumption.
Anyone has got any idea?
Thanks,
Nik.
