WARNING, DO NOT USE, PLEASE READ.
So I purchased a pair of these the other day.
http://www.customled.co.uk/products/canb...-canceller
After fitting both I turned on the car, cleared the errors and both bulbs working, then all of a sudden I see smoke coming out.
Turned the car off and it was one of them on fire,
They were plugged in tightly and the correct way.
Be careful
[Video: http://youtu.be/QuBuUAZBzw0]
[url=http://postimg.org/image/4nq3m6rc
Brake Assist Warning Light
I have a 2010 Astra SRI and the brake assist (BAS) has just starrted showing a warning
I haent found much information from googling.
Im hoping its a simple thing like the sensor on the brake servo[ATTACH=CONFIG]220[/ATTACH]
Any advice?
TESCO Diesel warning
Diesel warning
It would seem there are problems down my way with Tesco Diesel so please be aware of this...
Some have said it's got paint stripper in.
http://www.bournemouthecho.co.uk/news/11.../#comments
Light sensor warning!
[ATTACH]469[/ATTACH]
Hey again guys, I keep getting this error for both sides, but not always, it appears when I switch the lights on... Its strange. Any ideas?
Tail light warning message
Hello everybody.
I have changed the rear brake light bulbs to the LED bulbs philips and now every time i have a message that i need to check "stop" bulbs. Is it possible to turn off checking this "stop" bulbs?
Thanks in advance and sorry for my poor English.
HOW-TO DPF WARNING LED
[align=center]How-to DPF warning LED.
You must understand that the way this works means that if you turn on your rear demist the LED will turn on also and that you would have to turn it off to see if a DPF regen is taking place.
Ok the first thing you need to do is get a 12v LED like below.
Blue, [url=http://www.ebay.co
Airbag Warning Message
Hi All
So as my local mechanics are hopeless and getting them to do work is like pulling teeth I thought I'd see if anyone on here knew anything about an error I'm getting.
It pops up randomly 2 to 3 times per one hour journey and sometimes stays in for 30 mins before going off. The dash says this:
[Image: http://uploads.tapatalk-cdn.com/20160925...d2a582.jpg]
The error message via OBD says this:
[IMG]http://uploads.tapatalk-cdn.com/20160925/e68d66bd3b103ec5f2ba6
Fitted rear led lights, now bulb warning issues
So i have bought a new GTC, it came with no led rear lens, so got the dealer to order and fit them. Now he says it throws up rear bulb light failure display on the dash. Pressing the button on the steering wheel stalk turns of the issue warnings. can live with that , but is there a way to eliminate this, a guy told me you can go into the ecu and change the settings in the codes menu.
Service power steering warning light.
My car has this warning come on and the steering goes very heavy and it's pretty dangerous when it happens whilst driving.
It will then turn off and then not come on again for a few days.
Has anyone had an issue with this before? I've had a brand new steering rack put in and checked the battery and alternator which are both fine.
Thanks.
Sent from my Pixel 2 XL using Tapatalk
Abs light and service esp warning 1 week before MOT [emoji24]
Hello,
Nightmare scenario 1 week out from MOT ABS light and Service ESP message along with the traction control light have come on.
I have opcom and I tried firstly to clear all faults lights came straight back.
The only portion of the diagnostic code i can see is as follows:
**********************ECU ID STARTS**********************
Source Address: EBCM
Identifier: 0x2B02
Number of stored fault codes: 2
C0110 - Pump Motor Circuit
(00) - Present
