| Welcome, Guest |
| Latest Threads |
Astra J 2014. Electric st...
8:th-Sep-2025, 21:22:49
Factory Reverse Camera, A...
Forum: Retrofit How-to's
Last Post: obsidian
30:th-Aug-2025, 20:00:16
» Replies: 34
| How Remove Flex Ride |
Posted by: Sergio Pinto - 3:rd-Dec-2020, 16:38:07 - Forum: Retrofit Research
- Replies (4)
Sorry for my English, I'm from Portugal.
I have an Astra J 2011 1.6 turbo, I would like to remove the shock absorbers and the system (Flex ride) without giving errors.
They can help.
Regards
Sérgio
| How do you check gearbox oil on A20DTH/160ps? |
Posted by: Vx-Mad-G - 2:nd-Dec-2020, 13:01:11 - Forum: Mechanical
- Replies (3)
We have a 2011/11 Astra J CDTI 160.
Always felt the gears are a bit stiff, is there a way of checking the oil level, or does something else somewhere else need some lubrication?
Comparing to my other cars, both Insignia's with the same engine, the Astra really requires more force on the gearstick to engage, not harsh, but noticably more pressure.
Clutch is fine, we have had to four years and its been the same since day 1.
Thanks.
| Oil Cooler 1.4T |
Posted by: Bear - 1:st-Dec-2020, 10:15:49 - Forum: Astra-J/GTC
- Replies (4)
Does anyone know what the part number is for the Oil Cooler on an Astra J 1.4T (2013) as mine has a bad leak
| tpms fault |
Posted by: badger64 - 28:th-Nov-2020, 22:29:28 - Forum: Astra-J/GTC Common Problems
- Replies (2)
my tpms readings are no longer reading anywhere near accurate anymore, for some reason o/s/r and n/s/f are now reading under by about 6 psi, also this week on 2 mornings (cold) the dash warning light was on. i have set fronts at 37 psi and rears to 31 psi and checked them with a seperate digital gauge so no readings are correct, but dash says different, i have re-learnt the readings on display. has anyone else had this issue?
| CD400 power problem |
Posted by: bigles - 24:th-Nov-2020, 15:33:40 - Forum: Electrical
- Replies (6)
Hi all - I have a 2009 Astra 1.6 SE. In the mornings, when the car has been unused overnight, when I switch the radio on it comes on and then goes through between 4 and 6 restarts. The screen goes blank and the sound ceases each time, it comes on for about 5-10 seconds, goes off, and on again, etc. Once it has gone through this cycle it stays on and is OK for the rest of the day.
I've looked on the web but can't find anything specific to this problem. Any guidance before I start dismantling the centre console - I'm thinking a wiring harness problem (loose connection), maybe the car battery voltage is low first thing in the day (although I did check the voltage and was over 12.4 volts), a failure of the head unit such a main board breaking down?
Has anyone had similar problems or is there a known problem with these units.
My unit has bluetooth for the phone.
| #BlackFriday Discount Code: SANTA226 |
Posted by: ChrisKnottIns - 23:rd-Nov-2020, 17:43:02 - Forum: Chris Knott Insurance
- No Replies
Black Friday is great - but one-day deals aren't enough! That's why this year we're extending our discount so you can use it ANYTIME FROM NOW UNTIL THE END OF 2020.
12 months' UK Breakdown Cover for the price of 11*
Simply get a quote online or by phone and use PROMO CODE: SANTA226 to receive a discount on our comprehensive breakdown cover:
- HomeStart
- Roadside Assistance
- Recovery
- Onward Travel
- Overnight Stay
- 24hr Hire Car
- Relief Driver
- Message Relay
- callouts for flat batteries, running out of fuel, accidental tyre damage and lost/broken keys included as standard
Chris Knott's UK Breakdown Cover normally costs just £63 for a single vehicle. Use this promo code to get £5 OFF - 12 months' cover for the price of 11 - only £58. There are other discounts for multi-car cover too.
Quote & Buy online:
https://www.chrisknott.co.uk/rescue/?ref=BFFO
Get a phone quote:
0800 917 2274
Don't forget to mention/enter Promo Code SANTA226 to receive your guaranteed discount.
best,
Nick
Chris Knott UK Breakdown Cover - Testimonial:
"I can thoroughly recommend Chris Knott's breakdown service. I have it on both my vehicles (one 11 years and one 15 years old) and although I thankfully have only had to use them once, they were absolutely fantastic. And at a much better price than the 'big brands' too!" robt100, Briskoda.net
*£57.75 to be rounded to nearest whole £ = £58.
| Turbo failure common? |
Posted by: Euroshopper - 19:th-Nov-2020, 16:33:33 - Forum: Astra-J/GTC
- Replies (2)
Hello,
I had my car at service and they told me I had to change my turbo. Is this a common problem?
The fault codes was P0299 and P003A.
Is there any knows issues with the turbo on this car? It has only gone 75000 km / 46000 miles
Opel astra J, 2010, 1.3 CDTI.
Kind regards
