check gearbox you a20dth 160ps? oil do how on
How do you check gearbox oil on A20DTH/160ps?
We have a 2011/11 Astra J CDTI 160.
Always felt the gears are a bit stiff, is there a way of checking the oil level, or does something else somewhere else need some lubrication?
Comparing to my other cars, both Insignia's with the same engine, the Astra really requires more force on the gearstick to engage, not harsh, but noticably more pressure.
Clutch is fine, we have had to four years and its been the same since day 1.
Thanks.
No real way to check the level on the box.
My advise would be a cable adjustment may need 3 goes.
If you notice an improvement then all good. You can then decide if you want to do a gearbox oil change.
How do you do that adjustment? How do I get underneath the gear stick?
https://www.vxoc.org.uk/forum/Thread-How...ge-F40-Box
  2.0 CDti auto gearbox fault Big Dave2 2 4,143 1:st-Jul-2021, 13:14:50
  F40 gearbox oil. Willi G 3 11,600 9:th-Sep-2020, 01:32:45
Last Post: M222RJF
  DOOR CHECK STRAP STOP FRONT RIGHT Making clicking noise caretaker 4 8,559 7:th-Aug-2019, 17:12:16
Last Post: caretaker
  Gearbox Issues :( tommyboy1289 9 12,542 27:th-Mar-2017, 15:40:57
Last Post: Boroboy
  GTC Auto Gearbox bruce_19 7 11,136 5:th-Dec-2016, 21:39:55
Last Post: Boroboy
  GTC 2.0CDTI Gearbox issues yazza54 10 16,486 30:th-Nov-2016, 08:38:41
Last Post: yazza54
  Engine and Gearbox Combinations Rusty2009 9 25,097 27:th-Aug-2014, 19:37:28
