gearbox combinations engine and
Engine and Gearbox Combinations
[TR]
[TD]PETROL ENGINES[/TD]
[TD]ENGINE CODES[/TD]
[TD]ENGINE BUILD CODE[/TD]
[TD]GEAR BOX[/TD]
[TD]BHP[/TD]
[TD]MODEL[/TD]
[/TR]
[TR]
[TD]1.4 VVT[/TD]
[TD]A14XER[/TD]
[TD]LDD[/TD]
[TD]F17WR[/TD]
[TD]100 BHP[/TD]
[TD]J, ESTATE[/TD]
[/TR]
[TR]
[TD]1,4 VVT TURBO[/TD]
[TD]A14NET[/TD]
[TD]LUJ[/TD]
[TD]M32WR[/TD]
[TD]140BHP 125BHP[/TD]
[TD]GTC,J,ESTATE[/TD]
[/TR]
[TR]
[TD]1.4 VVT TURBO AUTO[/TD]
[TD]A14NET[/TD]
[TD]LUJ[/TD]
[TD]AF40[/TD]
[TD]140BHP[/TD]
[TD]GTC,J, ESTATE[/TD]
[/TR]
[TR]
[TD]1.6 VVT[/TD]
[TD]A16XER[/TD]
[TD]LDE[/TD]
[TD]F17CR[/TD]
[TD]115BHP[/TD]
[TD]GTC,J ,ESTATE[/TD]
[/TR]
[TR]
[TD]1.6 VVT TURBO[/TD]
[TD]A16LET
+A16XHT[/TD]
[TD]LLU LVP[/TD]
[TD]M32WR AUTO AF40[/TD]
[TD]180BHP[/TD]
[/TR]
[TR]
[TD]1.6 VVT AUTO[/TD]
[TD]A16XER[/TD]
[TD]LDE[/TD]
[TD]6T40[/TD]
[TD]115BHP[/TD]
[/TR]
[TR]
[TD]2.0 TURBO[/TD]
[TD]A20NFT[/TD]
[TD]LHU[/TD]
[TD]F40WR[/TD]
[TD]276BHP[/TD]
[TD]GTC ONLY[/TD]
[/TR]
[TR]
[TD]DIESEL ENGINES[/TD]
[TD]GEARBOX[/TD]
[TD]BHP[/TD]
[TD]MODEL[/TD]
[/TR]
[TR]
[TD]1.3 CDTI[/TD]
[TD]A13DTE[/TD]
[TD]LSF[/TD]
[TD]F17ER[/TD]
[TD]95BHP[/TD]
[TD]J,ESTATE[/TD]
[/TR]
[TR]
[TD]1.7 CDTI[/TD]
[TD]A17DTJ
+A17DTR+A17DTE[/TD]
[TD]LUE LPL LUD LKR[/TD]
[TD]M32WR[/TD]
[TD]110BHP
125BHP+130bhp[/TD]
[TD]GTC, J,ESTATE[/TD]
[/TR]
[TR]
[TD]2.0 CDTI[/TD]
[TD]A20DTH[/TD]
[TD]LBS,[/TD]
[TD]F40WR[/TD]
[TD]160BHP[/TD]
[/TR]
[TR]
[TD]2.0 CDTI AUTO[/TD]
[TD]A20DTH[/TD]
[TD]LBS[/TD]
[TD]AF40[/TD]
[TD]160BHP[/TD]
[/TR]
[TR]
[TD]2.0 BITURBO[/TD]
[TD]A20DTR[/TD]
[TD]LBY[/TD]
[TD]F40WR[/TD]
[TD]195BHP[/TD]
[/TR]
[TR]
[TD]1.6 CDTI[/TD]
[TD]B16DTH
+B16DTL[/TD]
[TD]LVM LVL[/TD]
[TD]M32WR[/TD]
[TD]135BHP 110BHP[/TD]
[/TR]
WR = Wide Ratio
CR = Close Ratio
ER = Economy Ratio
Thank-you to Tucpal for supplying all the above information
That has been sourced from vauxhall information sites.
Some more info relating to the gearbox's
Gearbox Specifications you can download below.
Word document
or
PDF document
Very nice. How much torque can the F40 handle?
the f40 is used on the biturbo so i would say somewhere near that
i have not heard of much problems with that box at all and it seems to cope well with remaps etc.
F40 Maximum Torque:- 295 lb-ft (400 Nm)
Nice one :-), time to look into that map then.
Added some more info first post.
i might remap mine after waranty to 167 bhp (from 120)
so im still wondering about the rempa. will the gearbox and engine be able to handle the extra power? or are they just made for 200nm and no more?
Check the downloadable PDF or word document mate it will tell the max the boxes can take. This info is from Vauxhall data.
sorry, missed that part. and wow 400nm i'm impressed, thats double than i have now. and i'm geussing it would not damage the engine either.
edit: i noticed that the F40's max is also 400nm, isnt that weird?
I don't know mate any good remapping place would know.
  2.0 CDti auto gearbox fault Big Dave2 2 4,197 1:st-Jul-2021, 13:14:50
  Engine oil level low ,Add oil Rocky33 0 3,719 14:th-Apr-2021, 12:56:53
Last Post: Rocky33
  How do you check gearbox oil on A20DTH/160ps? Vx-Mad-G 3 6,657 7:th-Dec-2020, 08:12:26
  F40 gearbox oil. Willi G 3 11,668 9:th-Sep-2020, 01:32:45
Last Post: M222RJF
  Intermittent low loss of engine power Mark72 2 9,615 28:th-Dec-2019, 13:59:37
Last Post: Mark72
  Cold engine idle Lee 4 14,234 15:th-Aug-2018, 19:09:17
Last Post: Lee
  Astra J 1.7 81kw engine power guitz 1 15,226 8:th-Jul-2018, 10:39:46
  URGENT HELP PLEASE: Distressed Engine Squeel/Groan Vx-Mad-G 13 31,274 30:th-Jan-2018, 15:55:51
Last Post: Vx-Mad-G
  Engine swap help joshparker1911 1 11,291 24:th-Jan-2018, 17:37:59
Last Post: vocky
  Fumes straight from engine bay Raf7007 2 11,369 21:st-Sep-2017, 23:57:16
Last Post: Simon Templar
