cold engine idle
Cold engine idle
Hi, I've just bought my first diesel and it happens to be a GTC SRI 2 ltr CDTi. I love it. My only question so far is that when I initially start the engine from cold, it's not a smooth idle and you can feel it through the car with a slight rocking. Is this normal? A common problem? After a few minutes, it idles fine and there seems to be no other issues. I searched for the answer before posting so apologies if the answer is buried here somewhere.
Thanks.
Lee
Welcome to the forum
Welcome to forum on cold start you can get some rough idle normally settles down quickly tho.
I tend to find it does it more if the battery is low on juice.
(15:th-Aug-2018, 17:58:06)Rusty2009 Wrote: Welcome to forum on cold start you can get some rough idle normally settles down quickly tho.
Great! Thank you. I won't worry too much then.
(14:th-Aug-2018, 20:57:01)Jpbroad1970 Wrote: Welcome to the forum
Thank you
  Running rough at specific Idle speed? everson38 0 3,858 20:th-Jun-2021, 21:30:30
Last Post: everson38
  Engine oil level low ,Add oil Rocky33 0 3,661 14:th-Apr-2021, 12:56:53
Last Post: Rocky33
  Rattle on cold startup last about 10 seconds help Paulmcn21 4 6,997 28:th-Dec-2020, 11:09:24
Last Post: M222RJF
  Intermittent low loss of engine power Mark72 2 9,548 28:th-Dec-2019, 13:59:37
Last Post: Mark72
  Astra J 1.7 81kw engine power guitz 1 15,153 8:th-Jul-2018, 10:39:46
  Gears hard to select when cold Amazingusername 8 10,453 9:th-Feb-2018, 20:20:45
Last Post: Iaintruten
  URGENT HELP PLEASE: Distressed Engine Squeel/Groan Vx-Mad-G 13 31,144 30:th-Jan-2018, 15:55:51
Last Post: Vx-Mad-G
  Engine swap help joshparker1911 1 11,230 24:th-Jan-2018, 17:37:59
Last Post: vocky
  Fumes straight from engine bay Raf7007 2 11,300 21:st-Sep-2017, 23:57:16
Last Post: Simon Templar
  Engine over heated no oil kyle-astra-j 6 10,942 1:st-Jun-2017, 11:22:20
Last Post: kyle-astra-j
