about help rattle cold seconds last 10 startup on
Rattle on cold startup last about 10 seconds help
Hi guys I have a Astra 2.0 cdti 14 plate and recently it has started making a lot of noise when completely cold on startup but only then. After it’s been started it doesn’t do it at all. I’ve had cam belt don’t and water pump done when I bought the car 6months. Not sure if it’s chain or belt on these and if the tensioner could be at fault or possibly dual mass maybe ?? Any ideas thanks
Paul
They are belts on these as I have same model.
Be interesting to hear a sound clip
Mmm ok. I’ll try get a clip. It’s still under warranty till January so I’ll get it into a garage and get it looked at. Can’t think what it could be since it’s a belt. Think the dual mass could cause the issue or possibly aux pulley ?
Mine sometimes make a rattle if it's been stood for a while & cold. last for about 5seconds then fine.
Did you get a new aux belt also?
  Cold engine idle Lee 4 13,900 15:th-Aug-2018, 19:09:17
Last Post: Lee
  Gears hard to select when cold Amazingusername 8 10,035 9:th-Feb-2018, 20:20:45
Last Post: Iaintruten
