Brake dust cover rattle
I think the dust cover behind one of my discs is rattling. When ever I go down a rough road there is a very annoying rattle, it also rattles when I kick the tyre.
Does anyone know the best way to stop this?
Intermittent engine rattle noise
Hi all new to here bought my first Astra 3monthd ago it's an Astra j 1.6 cdti ecoflex 136ps. The problem I am having is an intermittent loud rattleing noise on startup. It sounds like it's coming from the throttle body/egr area. Sometimes rattle clears after a few seconds sometimes stays if you turn the car off and restart the rattle is gone seems like something is sticking if that makes sense. I have no eml lights on. Also got an intermittent slight rough idle as well not shore if the problems
Squeek/Rattle when starting engine
Morning all, wondering if somebody could please shed some light
Had my car sitting at work for 9 hours yesterday and when I started it I heard a 2 second ish rattle/squeek which I'm unaware of and this has never happened before. I turned the car off and on again but didn't hear it again. Around 10pm last night I had to move my car, so turned it on after it been sitting with no movement for 5 hours, cold engine but heard nothing. Then again this morning I heard the squeek/rattle again
Any i
A Post rattle GTC
Hi there
Anyone ever had to repair a rattle on an Astra GTC drivers side A post?
Rattle on cold startup last about 10 seconds help
Hi guys I have a Astra 2.0 cdti 14 plate and recently it has started making a lot of noise when completely cold on startup but only then. After it’s been started it doesn’t do it at all. I’ve had cam belt don’t and water pump done when I bought the car 6months. Not sure if it’s chain or belt on these and if the tensioner could be at fault or possibly dual mass maybe ?? Any ideas thanks
Paul
