20:th-Jan-2018, 20:40:55
I have an astra 2.0 cdti 2012 and when the car is cold the gears are hard to select and feel stiff until the car is warm. Then everything is fine!!
| to gears cold select hard when |
Gears hard to select when cold
21:st-Jan-2018, 09:13:29
That's normal a cable adjustment can help abit and gearbox fluid change may also help but it never fully goes away
22:nd-Jan-2018, 13:27:15
2.0 Cdti is notchy from 1st to 2nd when cold. It's OK after a few minutes.
Past 2015 Ford Focus 1.5 Titanium X Past 2012 VX Astra 2.0 Cdti Sri Vx Line Past 2008 Civic 1.8 Type S
22:nd-Jan-2018, 16:10:47
1.7 too for that matter
28:th-Jan-2018, 12:58:59
I found that when I fitted my short shifter and greased all of the moving parts including the ball joint of the gear stick, rods and the shifter itself, gear changes are much smoother.
29:th-Jan-2018, 03:29:52
(This post was last modified: 29:th-Jan-2018, 05:21:52 by Iaintruten.)
Hopefully after the end of today I won't be worrying anymore with the notchy gearbox since I'm picking up my new focus at end of today as long as my white astra makes it
29:th-Jan-2018, 05:22:15
I will still be on this to try and help people as there is a good bunch of guys on here.
9:th-Feb-2018, 20:15:22
Good stuff. Enjoy your Ford focus, I hope you don't have any problems with it as I've heard that there might be a cam sprocket issue with them. 1.5 motor.
9:th-Feb-2018, 20:20:45
(This post was last modified: 9:th-Feb-2018, 20:22:08 by Iaintruten.)
Yeah mines going in on Monday for that exact recall as I cracked up today that they sold me the car with that recall still outstanding lol so they are doing that as well as new timing belt etc under the recall.
Sent from my SM-N950F using Tapatalk |
« Next Oldest | Next Newest »
| Rattle on cold startup last about 10 seconds help | Paulmcn21 | 4 | 6,751 |
28:th-Dec-2020, 11:09:24 Last Post: M222RJF |
| Astra J 2011 1.7Cdti Juddering in higher gears | Mark72 | 6 | 10,603 |
10:th-Jun-2020, 10:08:54 Last Post: Mark72 |
| Cold engine idle | Lee | 4 | 13,903 |
15:th-Aug-2018, 19:09:17 Last Post: Lee |
| Who read this thread? |
| 1 User(s) read this thread: |
| gemini6791 (15:th-Sep-2025, 14:37:14) |
