How to front and rear brake pads removal 5Door
How to front and rear brake pads removal.
Just thought I'd put this up as we don't have one yet.
Jack up and remove wheel from the car to gain access to brake.
[Image: https://www.vxoc.org.uk/Images/rusty/Brakes/1.JPG]
Next take out the guide bolt from the bottom 10mm
[Image: https://www.vxoc.org.uk/Images/rusty/Brakes/2.JPG]
you may need to
How to Install aftermarket head unit
[align=center][Image: https://www.vxoc.org.uk/Images/vxoc%20as...x.o.c.jpeg]
1. Make sure you have everything you need.
[Image: https://www.vxoc.org.uk/Images/rusty/How...unit/0.JPG]
If you don't know how to remove the factory unit then please see my [url=http://www.vxoc.org.uk/forum/Thread-How-to-remove-the-head-unit-from-the-car-includes-Screen-removal]Ho
How to retrofit flex floor Astra-J (MK6) 5 Door
Here is a list of the parts needed.
*Please note parts prices vary from dealer to dealer these are the prices I paid.*
[TABLE=Flex Floor Price list]
[TR]
[TD]Part Number[/TD]
[TD]Description[/TD]
[TD]Quantity[/TD]
[TD]Price[/TD]
[TD][b]Cheaper pric
How-to remove front bumper from Astra-j (MK6 5 Door Facelift)
[align=center]How-to remove front bumper from Astra-j (MK6 5 Door Facelift)
Tools needed
*Trim tools
*Torx 10 bit
*Socket Set
The first thing you need to do is remove 3 torx 10 screws on each side of the wheel arch.
[Image: https://www.vxoc.org.uk/Images/rusty/How...mper/1.JPG]
Then there is small bolt where the bumper
How To Remove Rear bumper
[Image: https://www.vxoc.org.uk/Images/rusty/pos...mper/1.jpg]
Start by taking the rear lights off to do this there is a wingnut behind each light unit.
[Image: https://www.vxoc.org.uk/Images/rusty/pos...mper/2.jpg]
Then pull the light unit towards you then right or left (my
How to remove the head unit from the car includes Screen removal
How to remove the head unit from the car.
Includes Screen removal.
Tools needed
* Cross head screw driver
* 7mm socket
*Small slot head screw driver or paper scraper.
Here's how it look to start.
[Image: https://www.vxoc.org.uk/Images/rusty/pos...dio/00.jpg]
1. Remove the non-slip mat.
[img]https://
Upgrade to alloy door pins
HOW TO CHANGE DOOR PINS
Possibly the Cheapest Upgrade Here
and a very easy and Simple job to do 5 Minutes Max.
Just Unscrew the Original Plastic Door Pins by hand
and Turn the New ones Back in.
[Image: http://i179.photobucket.com/albums/w301/...5690d8.jpg]
[Image: http://i179.photobucket.com/albums/w301/...d47629.jpg]
They c
how to change speakers
How to change speakers
to remove door cards please see remove door cards how to
Tools needed
*7mm Socket
*Trim tools
*Phillips Cross head screw driver
*Torx 10 bit
*Stanley knife
*Wire cutters
*Crimping tool
*Soldering Iron (optional)
Here's everything I have.
[Image: https://www.vxoc.org.uk/Images/rusty/how...kers/1.JPG]
fit
How-to remove Window trims & door mirrors
How-to remove Window covers & door mirrors
Tools needed
*Trim tools
*10mm Socket
if replacing the mirror/s you will need to remove the door cards How-to Here.
So to start this is what we have (you may not have wind deflectors fitted).
[img]https://w
How to ambient door lights
This is a How To for the Door Ambient LED Lights
There are now two Versions of this How to so this is Version one
Using the Correct LED but Taking Power
from the Window Switch Ambient Light Circuit
this means they will come on when you Open the Door
and go off when you Close the Door
and stay on when you Turn the Side Lights or Headlights on
i have my Lights wired like t
