car started then cut out after a few seconds
So yesterday on my run to the Port I had to relieve myself so Stopped at the services went in and used to toilet.
Came back started the car no problems at all it ran for 2-3 seconds then cut out only message to pop up was to press clutch to start.
Tried a few time and nothing every time I turned the key all the lights went out on the dash in the end I had to take the key out and then it was all ok.
Anybody any ideas or had it happen to them?
HIDS go off after a few seconds.. Help!
Hi guys
I fitted a set of 6000k HIDS today and they work fine with the engine off, but if I start the car they will switch on then after a few seconds they flicker and go off, then won't come back on until I turn the engine off then switch them off then back on again.
Help?
PS please no slating that I don't have projectors!
[Image: http://i1279.photobucket.com/albums/y527...kla1cx.jpg]
Cooling Fan coming on for a few seconds
Recently on two occasions after I have driven the car for a while,  stopped and then re start the cooling fan has come on for a few seconds.
Could this be related to the thermostat wiring harness issue they had?
It is a 1.6 Petrol Auto
dp
Rattle on cold startup last about 10 seconds help
Hi guys I have a Astra 2.0 cdti 14 plate and recently it has started making a lot of noise when completely cold on startup but only then. After it’s been started it doesn’t do it at all. I’ve had cam belt don’t and water pump done when I bought the car 6months. Not sure if it’s chain or belt on these and if the tensioner could be at fault or possibly dual mass maybe ?? Any ideas thanks
Paul
