fault tpms
tpms fault
my tpms readings are no longer reading anywhere near accurate anymore, for some reason o/s/r and n/s/f are now reading under by about 6 psi, also this week on 2 mornings (cold) the dash warning light was on. i have set fronts at 37 psi and rears to 31 psi and checked them with a seperate digital gauge so no readings are correct, but dash says different, i have re-learnt the readings on display. has anyone else had this issue?
I know there is always a slight difference on the dash but I think it's about 2psi either way (but don't hold me to that).
In terms of the light being on cold mornings some people do say this but I have never had it happen in my Astra and so far not happened in the Mrs Mokka.
I do believe the batt's going low will not help with readings (they meant to last min 10yrs but quality of things these days is questionable).
(2:nd-Dec-2020, 14:52:39)Rusty2009 Wrote: I know there is always a slight difference on the dash but I think it's about 2psi either way (but don't hold me to that).
ok, thanks for the reply rusty. it hasnt happened again as temperatures have been a bit warmer see if the warning light comes back on when temperatures drop below freezing again. as for the discepencies on the dash i think i'll just have to manually check pressures.
  Newbie Urgent Wiper Washer Fault help ronseal 8 8,901 21:st-Aug-2020, 07:15:09
  Astra J. Can a tyre valve be replaced without replacing the TPMS? benawhile 2 8,057 5:th-Aug-2020, 12:33:14
Last Post: benawhile
  Intermittant hatch unlocking fault Big Dave2 4 7,279 17:th-Jun-2018, 07:52:42
  abs fault custardsastra 2 6,995 19:th-Mar-2017, 08:17:03
