Howto Retrofit TPMS
Howto Retrofit TPMS
Ok the first thing we need to do is check a couple of things.
Pins in the rear fuse board.
The most important one is the one at the bottom.
[Image: https://www.vxoc.org.uk/Images/rusty/How...PMS/00.jpg]
[Image: https://www.vxoc.org.uk/Images/rusty/How...PMS/01.jpg]
You will also need to check you have the following wi
tpms
TPMS & Bluetooth
I've just bought a late 2013 gtc 2.0 diesel sri and was wondering if they all came with Bluetooth & TPMS, because both options are missing from the menus on mine. Tia
TPMS came on unexpectedly.
TPMS light came on today whilst zooming down the motorway.
Blank reading on the rear offside tyre. Nothing wrong with it at all.
Turned off motorway & checked it out. Fiddled with tyre cap still on, drove a further 300 yds pulled in & switched engine off & back on. 2 mins later the TPMS light went out, thank god.
Anybody know why this would happen & how i could reset it, should it come on again.
Tpms sensor.
Hi guy was wondering if anyone knows how to activate a new tpms sensor that I had to replace as when I changed my tires the core was seized in and snapped when removing it. I was told by Vauxhall the new one should automatically set to car but it’s flashing the tpms symbol on the dash and seeing as it’s first mot is due at end of month really want it sorted.
Cracked tyre valve with TPMS
Hi all
I went to put air in my tyres today and noticed that the metal valve is cracked on one of my wheels and therefore I am unable to put air in. Is this a cheap tyre shop job or will the whole sensor need replacing?
Thanks very much
TPMS Sensors on wheels but not on car
Last night I purchased some new wheels for my car, and I suspect they may have TPMS sensors fitted, but my car doesn't have TPMS.
I have a couple of questions:
  1. Can I still use these wheels with the sensors installed?
  2. Is it possible to replace the sensors with normal valves?
service parking assist and tpms not working
hi guys
im new to the forums,was just wondering what i might have done wrong with wiring up my dash cam to green and white wire before it gets to back of rear fuse box.
seems its knocked out the parking sensors(getting the service parking assist warning on dash)and the tpms is not working,ive checked the fuse for parking sensors and its still fine plus theres a 12 volt supply to it also.
any help would be appreciated
Insignia tpms
I have a question regarding my car.
I have a 2011 SRI nav with 18inch alloys.
It appears the wheels have the tpms sensors built in but there doesnt seem to be an option within the car to monitor the pressures.
Is this normal for my age of car? On the earlier version is it just the light on the dash which illuminates?
Alex
tpms fault
my tpms readings are no longer reading anywhere near accurate anymore, for some reason o/s/r and n/s/f are now reading under by about 6 psi, also this week on 2 mornings (cold) the dash warning light was on. i have set fronts at 37 psi and rears to 31 psi and checked them with a seperate digital gauge so no readings are correct, but dash says different, i have re-learnt the readings on display. has anyone else had this issue?
