6 115 j perhaps timing outer belt astra too and 1 a16xer hp 2010
Astra J 1.6 A16XER (115 hp) 2010 Outer Belt (and perhaps Timing Belt, too
So 77 000 km behind and 10 years, outer and timing belt not yet changed. Heard that when changing outer belt you have to release the tensioner by taking the right inner wing away etc. Is it so? Any tips. Perhaps time to do timing belt, too? Is it normal job (done V6 several times so basically I can do it but never touched 1.6). What is timing belt change interval? How about water pump? Recommendation for kits?
I don't see the wing has to come off the wheel and maybe arch liner for better access.
  Astra J manual – pedal box gone? pretty expensive! Mr Writer 5 12,376 9:th-Sep-2021, 14:27:28
Last Post: Gav-Astra
  weird motor sound Astra J 1.4 turbo oliv.cleiton 2 2,056 18:th-Jul-2021, 08:17:49
  Astra A17DTF - Timing Belt or Chain? everson38 1 1,575 17:th-Jun-2021, 12:03:07
  Astra j mirrors Kiel0777 2 2,144 15:th-Apr-2021, 20:34:53
Last Post: Kiel0777
  Astra won't start after some sensor cleaning? momoomar 2 3,246 3:rd-Oct-2020, 02:04:44
Last Post: momoomar
  Auxiliary Belt failure - cam belt change question David` 8 3,865 27:th-Aug-2020, 17:57:38
  Changing Rear Shock Absorbers. Astra-J Hatch. Replace or reuse bottom bolts? Big Dave2 5 5,203 22:nd-Jun-2020, 11:35:40
  Astra J 2011 1.7Cdti Juddering in higher gears Mark72 6 5,310 10:th-Jun-2020, 10:08:54
Last Post: Mark72
  Astra 2.0cdti dpf regen info? Boroboy 19 21,731 5:th-May-2020, 14:22:14
Last Post: Kiel0777
  2013 Astra J SRI Galway11 2 4,009 29:th-Jun-2019, 20:20:47
