timing a17dtf chain? belt astra or
Astra A17DTF - Timing Belt or Chain?
Hey guys, I have a 62 plate. 1.7 GTC Diesel A17DTF.
Simply does anyone know if it is chain or belt driven, saw the bolts to remove and could not be bothered to do that to check lol.
Sent from my moto g(8) plus using Tapatalk
It's a belt I believe
  astra j shock on standard vs lowered sport chassis obsidian 1 2,994 19:th-Apr-2025, 19:19:09
  Astra J manual – pedal box gone? pretty expensive! Mr Writer 5 16,940 9:th-Sep-2021, 14:27:28
Last Post: Gav-Astra
  weird motor sound Astra J 1.4 turbo oliv.cleiton 2 4,988 18:th-Jul-2021, 08:17:49
  Astra j mirrors Kiel0777 2 4,160 15:th-Apr-2021, 20:34:53
Last Post: Kiel0777
  Astra won't start after some sensor cleaning? momoomar 2 6,515 3:rd-Oct-2020, 02:04:44
Last Post: momoomar
  Auxiliary Belt failure - cam belt change question David` 8 9,814 27:th-Aug-2020, 17:57:38
  Astra J 1.6 A16XER (115 hp) 2010 Outer Belt (and perhaps Timing Belt, too Acond 1 7,324 14:th-Aug-2020, 14:35:21
  Changing Rear Shock Absorbers. Astra-J Hatch. Replace or reuse bottom bolts? Big Dave2 5 12,247 22:nd-Jun-2020, 11:35:40
  Astra J 2011 1.7Cdti Juddering in higher gears Mark72 6 10,490 10:th-Jun-2020, 10:08:54
Last Post: Mark72
  Astra 2.0cdti dpf regen info? Boroboy 19 34,516 5:th-May-2020, 14:22:14
Last Post: Kiel0777
