Cam belt. .
What is the recommended mileage , at which the cam belt should be changed on the 1.7 CDTi diesel. .
Rear seat belt buckle
I'm going to retrofit the rear seat belt buckle with sensors,
I've ordered both the buckles cost £29.00 posted as opposed to £110+.
I have the wiring diagram just can't seem to locate the terminals for it so if anyone can help that would be good, even if you know what other Vauxhall car it's fitted and where it is I can go up the scrappy and get one.
[Image: http://vxoc.org.uk/Images/rusty/K36.bmp]
Connector Part Information
Harness Type: Body
OEM Connector: 19151247
Service Connector: 1
Astra-J 2.0 Timing belt kit brand new
VAUXHALL TIMING BELT KIT 2.0 DT/DTH DIESEL 2009> INSIGNIA*ASTRA J* 95507810
Price: £41.99
If you want to save lots of money then buy one quick they are brand new and genuine At that price I ordered one and I still have 4 years to go before I need to change mine.
http://www.ebay.co.uk/itm/351193061681?_...EBIDX%3AIT
£120 from Auto vaux http://www.autovaux.co.uk/product/955078...tsset.aspx
Cam belt cost
Hi all, only had the gtc for 3 weeks now and loving every minute of driving.... I'm on 72000 miles now and a cam belt change isn't too far away ( I do 2000 miles a month ) ... It's a 2.0 cdti on a 12 plate
Roughly how much does it cost to have them replaced , when I had an Audi A3 it was good practice to have the water pump and tensioner a replaced at the same time .....is it the same with the VX ?
Cheers James
timing belt and water pump
Hi all. I just want to ask when i should change my timing belt and water pump? I have a gtc 2l cdti with 56000 miles. When do i need to change. Im not sure if it has ever been done as their is no record. Only had car 8 months. Any advice appreciated. I dont want to wait incSe my engine gets ruined. Thanks for your help. Regards
Timing Belt query
My Astra is a 2011 model on a 60 plate and has a 1.7 cdti (125) engine. The mileage is sitting at 58k right now. When should the timing belt be changed and are there any pumps etc that need looked at at the same time?
After some digging about on the internet i seem to be coming up with loads of different answers to my question. 100k/10 years 100k/6 years 60k/6 years. Obviously i don't want to get it done the now if its a 100y/10k ratio. Hopefully someone on here can help.
Sent from my SM-G90
Timing Belt and Water pump change
Does anyone have a how to guide for changing the Timing belt and Water pump on a 2014 Vauxhall Astra 2.0 Diesel?
Engine code A20DTH - 17C48924LBS
No sound on indicators, seat belt warning and quiet front parking sensors
Wondering if anyone can help.
I had some work done recently to replace the passenger side wing mirror and glass on drivers side door, resultant of my GTC being vandalised.
The issue I have (and have pointed out to the repairers when I picked the vehicle up from), is that I no longer have indicator, seat belt and almost inaudible front parking sensor sounds. All these were in good working order before the car was broken into and sent off for repair.
I guess the chimes etc go through spe
Rear Seat Belt Buckle-Drivers Rear-Single
Hi guys,
Im after a Rear Seat Belt Buckle please, I dont know if I have got the naming correct, but its basically what the rear seat belt plugs into.
I only need the single one, which is driver rear.
My car is a 2011 Elite, so dont know if its different on the other editions.
Many thanks.
Astra J 1.6 A16XER (115 hp) 2010 Outer Belt (and perhaps Timing Belt, too
So 77 000 km behind and 10 years, outer and timing belt not yet changed. Heard that when changing outer belt you have to release the tensioner by taking the right inner wing away etc. Is it so? Any tips. Perhaps time to do timing belt, too? Is it normal job (done V6 several times so basically I can do it but never touched 1.6). What is timing belt change interval? How about water pump? Recommendation for kits?
