Astra-J 2.0 Timing belt kit brand new
timing belt and water pump
Hi all. I just want to ask when i should change my timing belt and water pump? I have a gtc 2l cdti with 56000 miles. When do i need to change. Im not sure if it has ever been done as their is no record. Only had car 8 months. Any advice appreciated. I dont want to wait incSe my engine gets ruined. Thanks for your help. Regards
Timing Belt query
My Astra is a 2011 model on a 60 plate and has a 1.7 cdti (125) engine. The mileage is sitting at 58k right now. When should the timing belt be changed and are there any pumps etc that need looked at at the same time?
After some digging about on the internet i seem to be coming up with loads of different answers to my question. 100k/10 years 100k/6 years 60k/6 years. Obviously i don't want to get it done the now if its a 100y/10k ratio. Hopefully someone on here can help.
Sent from my SM-G90
Timing Belt and Water pump change
Does anyone have a how to guide for changing the Timing belt and Water pump on a 2014 Vauxhall Astra 2.0 Diesel?
Engine code A20DTH - 17C48924LBS
Timing locking kit help
Hi i am looking for a timing kit for my 1.6t a16let astra 2012 j series gtc.
It needs a head gasket change and maybe skim but need the timing tools first.
I see loads on ebay for the j series 1.0 1.2 and 1.4 but not the 1.6turbo.
I have found one lazer kit but says a16xht instead 1.6sidi so might be wrong one. the 40 ebay ones are usually what i use As this is a one time use i dont mind the cheaper kits if i can find them. I have a few cheapers kits and they do fine for non commercial use.
GTC 1.4 T timing chain change?
I'm trying to find info on how often this is, but i keep finding conflicting info. Belt changes seem to say anywhere from 60k to 100k and chain changes say 60k/150k and the life of the car. Any idea on the real answer?
Acond - Replies:
Astra J 1.6 A16XER (115 hp) 2010 Outer Belt (and perhaps Timing Belt, too
So 77 000 km behind and 10 years, outer and timing belt not yet changed. Heard that when changing outer belt you have to release the tensioner by taking the right inner wing away etc. Is it so? Any tips. Perhaps time to do timing belt, too? Is it normal job (done V6 several times so basically I can do it but never touched 1.6). What is timing belt change interval? How about water pump? Recommendation for kits?
BiTurbo timing belt
Happy new year all
I’ve searched online but find contradicting answers. Does anyone know the official Vauxhall recommended intervals for the timing belt on a 64 plate BiTurbo and is it recommended to do the water pump at the same time on this engine?
rodduz - Replies:
Timing belt for 1.7 2013
Astra A17DTF - Timing Belt or Chain?
Hey guys, I have a 62 plate. 1.7 GTC Diesel A17DTF.
Simply does anyone know if it is chain or belt driven, saw the bolts to remove and could not be bothered to do that to check lol.
Thanks[Image:
https://uploads.tapatalk-cdn.com/2021061...54318d.jpg ]
