Kpal11 - Replies:
2014 Astra 2.0L 165 HP F40 gearbox quantity of oil??
I have searched around on so many forums now and unable to find a definitive answer as I have heard rumours of vauxhall overfilling the F40 gearbox so I have heard it holds 2.4L, 2.6L, 1.9L, I dont have a clue how much is in thereor whether should be putting in less than what I get out because that what I have seen on a few forums. Would really appreciate some guidance on this!! All I do know is I will be using Redline 75W-85 GL04 oil for it... but how much of it??? ??
Acond - Replies:
Astra J 1.6 A16XER (115 hp) 2010 Outer Belt (and perhaps Timing Belt, too
So 77 000 km behind and 10 years, outer and timing belt not yet changed. Heard that when changing outer belt you have to release the tensioner by taking the right inner wing away etc. Is it so? Any tips. Perhaps time to do timing belt, too? Is it normal job (done V6 several times so basically I can do it but never touched 1.6). What is timing belt change interval? How about water pump? Recommendation for kits?
seekar - Replies:
DPF problems cold weather 1.7 cdti 110 hp A17DTE
Hi, I have an astra j 2013 1.7 cdti 110 hp A17DTE and as soon as the weather has cooled it shows me that the DPF is full and to continue driving. What could be the reasons why the car makes so many regenerations if for example today I drove 1000 km on the highway and everything was ok and tomorrow morning when I start the car I get a warning with DPF on board. Any opinion is highly appreciated.
