j 2013 astra sri
2013 Astra J SRI
How do you check the following before going to garage...
Noise from clutch when pressed
Any links to check below queries appreciated
1  Faulty clutch release cylinder?
2  clutch pedal bushes
3  pressure plate spring
Ta
(27:th-Jun-2019, 22:50:10)Galway11 Wrote: How do you check the following before going to garage...
Ta
Hi sounds like the clutch release bearing other than what you have done do not know any other way of checking, in the good old days there used to be a inspection cover that you could remove to get a look at the bearing do not think they fit them anymore?
without hearing the noise, I'd also go for release bearing,
probably worth replacing the complete clutch assembly at the same time
  astra j shock on standard vs lowered sport chassis obsidian 1 2,967 19:th-Apr-2025, 19:19:09
  Astra J manual – pedal box gone? pretty expensive! Mr Writer 5 16,917 9:th-Sep-2021, 14:27:28
Last Post: Gav-Astra
  weird motor sound Astra J 1.4 turbo oliv.cleiton 2 4,970 18:th-Jul-2021, 08:17:49
  Astra A17DTF - Timing Belt or Chain? everson38 1 4,145 17:th-Jun-2021, 12:03:07
  Astra j mirrors Kiel0777 2 4,142 15:th-Apr-2021, 20:34:53
Last Post: Kiel0777
  Astra won't start after some sensor cleaning? momoomar 2 6,495 3:rd-Oct-2020, 02:04:44
Last Post: momoomar
  Astra J 1.6 A16XER (115 hp) 2010 Outer Belt (and perhaps Timing Belt, too Acond 1 7,295 14:th-Aug-2020, 14:35:21
  Changing Rear Shock Absorbers. Astra-J Hatch. Replace or reuse bottom bolts? Big Dave2 5 12,199 22:nd-Jun-2020, 11:35:40
  Astra J 2011 1.7Cdti Juddering in higher gears Mark72 6 10,430 10:th-Jun-2020, 10:08:54
Last Post: Mark72
  Astra 2.0cdti dpf regen info? Boroboy 19 34,428 5:th-May-2020, 14:22:14
Last Post: Kiel0777
StickeNZ (14:th-Jan-2026, 04:59:04)
