to mylink link wiring i 950 900 diagram navi
Navi 900 to I-link/MyLink 950 Wiring diagram
I want to upgrade my head unit to the I-link 950 unit.
So far i know its possible and have successfully changed the VIN on a MyLink unit out of a commodore (I'm an Aussie) and it does turn on and the radio works.
I'm 99% sure that the units store the VIN on the same chip on all devices (made by Panasonic).
I just need a wiring diagram from a Navi 900 and from a I-link 950 and then hopefully i can write a how to once i have done it.
The wiring is the same apart from the mic wires.
(5:th-Sep-2017, 10:08:45)Rusty2009 Wrote: The wiring is the same apart from the mic wires.
can you tell me what wires?
Vauxhall TIS is your best friend
(5:th-Sep-2017, 15:00:22)Jpbroad1970 Wrote: Vauxhall TIS is your best friend
tried that. for some reason it will not load images, help desk isn't being very helpful.
Help-desk won't be any help.
You need to install the plugin's & use IE.
(8:th-Sep-2017, 12:02:12)Rusty2009 Wrote: Help-desk won't be any help.
IE gives same problem. I think its a windows 10 issue.
I use it on win10 no problem , just make sure it uses explorer not edge. I think there are some hints in tis to tell you what plugins to use and win10 issues
  Astra J Instrument Cluster 32pin wiring diagram Milo629 3 10,513 2:nd-May-2025, 12:12:20
Last Post: dellpiron
  cd 400 upgrade to navi 600 need help goose9029 6 9,955 14:th-Feb-2024, 07:52:16
  vin relearn navi 600 geoffp 1 3,942 5:th-Jul-2021, 15:38:22
Last Post: livo
  Navi 650 bluetooth and reverse camera mislav_os 30 37,038 9:th-Jun-2021, 16:08:07
  tow bar wiring Dicko 57 63,134 6:th-Oct-2020, 07:25:45
  Navi 950 retrofit to Buick Encore vibalt 3 13,390 21:st-Jul-2020, 19:02:30
  navi 500 programming tzr608 14 21,935 15:th-Mar-2020, 23:15:54
  Front PDC Wiring leeso 1 4,042 15:th-Jan-2020, 19:43:02
QuickHeat & wiring W.I.P. Lansa 0 4,784 24:th-Feb-2019, 17:51:30
Last Post: Lansa
  Navi 950 intellilink centre dash speaker Kdun 4 7,306 13:th-Feb-2019, 08:12:21
jas7c5-2008 (30:th-Dec-2025, 20:07:17), Happy25 (13:th-Sep-2025, 12:11:26)
