tucpal - Replies:
Hidden menus CD500,600,800,900
Summit - Replies:
How to Install a Reverse Camera in an Astra J with Navi 900
Here is an installation guide for fitting a reverse camera to an Astra J with Navi 900. If you have the DVD 800, the installation is similar but you will probably need a
RGB interface box instead of the
GVIF interface used in the Navi 900. I presume Navi 600 is the same as Navi 900 as far as reverse camera's go but I cant be sure abou
tucpal - Replies:
how to edit nav600/900 theme files and start up animation.
[align=center][Image:
........... PART ONE .... HOW TO EDIT THEME FILES NAV 600 .... astra j / insignia ..............
You do This at Your own Risk if you Follow the How to Correctly
There Should be no Problems Thank You.
This how to will help you use the GM_RES_ PACKER/UNPACKER
and edit theme files on the Nav600 display
this will only work on a hacked Nav 600
C0ntax - Replies:
Navi 900 - 3rd Party Software?
Just bought a GTC with navi 900 installed but the navigation software is pants. Used it on the way from the dealers to get home, 90% on motorway, but it kept directing me off the motorway down roads that were not on my route.
Is it possible to simply have a 3rd party nav software, such as tomtom, on sd card and insert in the car or is this not possible?
raimon - Replies:
Download Link for reverting 900 - 600
raimon - Replies:
Navi 900 Logbook function
Hi folks,
Anyone on here tried using the Logbook function on the Navi 900 / Modded Navi 600?
It is a pretty neat feature. You can track your travels for personal use or business and the mileage of the car at the time.
bh03an - Replies:
Navi 600 to 900 upgrade problem! Help needed ASAP!
Navi 900 upgrade.
i want to upgrade m Navi900 unit to some after market unit, i want to keep it as stock as possible so steering wheel controls and centre buttons working and the climate controls on the screen. i've read that the wiring is different for navi900 modules.
I'm quite confident if i need to make changes to wiring ect but want to make sure its easy to revert back to stock.
thanks
Navi 900 to I-link/MyLink 950 Wiring diagram
I want to upgrade my head unit to the I-link 950 unit.
So far i know its possible and have successfully changed the VIN on a MyLink unit out of a commodore (I'm an Aussie) and it does turn on and the radio works.
I'm 99% sure that the units store the VIN on the same chip on all devices (made by Panasonic).
I just need a wiring diagram from a Navi 900 and from a I-link 950 and then hopefully i can write a how to once i have done it.
cd600 to 900 stuck
HELP has anyone got a working Navi 600 to 900 upgrade CD they could post to me i am stuck half way through having burned the image iso but cannot find how to copy the dnl file to disc any help would be appreciated as the head unit is useless at the minute i followed the instructions but hasnt worked and its stuck on boot 5 many thanks.
