tow bar wiring
Can any one get me a wiring diagram to wire my tow-bar electrics up
2.0 cdti 2011 NC11SUE
many thanks
Electric windows wiring
Wiring for front electric windows only.
[Image: http://www.vxoc.org.uk/Images/vxoc%20ast...AER%29.png]
Wiring for front and rear electric windows.
Drivers door
Passenger door
[img]http://www.vxoc.org.uk/Images/vxoc%20astra-j-gtc/Tech%20data
AFL Retrofit wiring 5-Door ONLY.
[Image: http://vxoc.org.uk/Images/vxoc%20astra-j...x.o.c.jpeg]
Another VXOC First.
****VERY IMPORTANT GM WILL NO LONGER SUPPORT THIS RETROFIT AND THEY WILL NOT SUPPLY A VCI
[align=center]CUSTOM PROGRAMMING IS NEEDED ONLY A SELECT FEW PEOPLE CAN DO THIS****
This only covers 5-door
Wiring
Hi Guys
Wondering which type of wiring you all use for the little bits of work you do...just run out of the last lot of wiring I had which I got from Halfords. Not sure if you all got a specific type. Sure it won't actually matter but thought I'd ask anyway
Wiring Crimping Help
I have a lot of wiring in my car (mainly ambient LEDs) which I've secured with a simple twist of the wire and some electrical tape...I'm fully aware how bad this is but I simply cannot solder well enough to do it in tight spaces.
Now I would like to know how to carry out in line crimping on spliced wires....Hope people know what I mean. Is this something that can be done...is there a sort of clamp which I can put over the wires and then crimp in place?
Mokka wiring loom
Does anybody know if the mokka share the same wiring loom throughout the whole range?!
Would like to know if it's possible to retrofit heated leather into a base model mokka
Joe
Reverse Camera wiring
Hey all
I've ordered a reverse camera to go wit my new head unit (when it arrives) and it requires power from the reverse light itself...Now I already have my reverse parking sensors wired into this reverse power light...So would it cause too much power draw to have the reverse camera wired into this same power cable?
Help wiring ambient lighting
Hi all can you help me out I'm adding so ambient lighting to my doors I follows the guide on here but as you can see on picture below why cant I add wire from switch straight down the door (green line )
I don't understand the ( purple bit ) where you put wires through please can some one help pictures thanks in advance.
[Image: http://i.imgur.com/rukNCQD.jpg]
Admin can remove I have sorted it now thanks ??
Navi 900 to I-link/MyLink 950 Wiring diagram
I want to upgrade my head unit to the I-link 950 unit.
So far i know its possible and have successfully changed the VIN on a MyLink unit out of a commodore (I'm an Aussie) and it does turn on and the radio works.
I'm 99% sure that the units store the VIN on the same chip on all devices (made by Panasonic).
I just need a wiring diagram from a Navi 900 and from a I-link 950 and then hopefully i can write a how to once i have done it.
No wiring for the interior boot light
Am I the only poor sod who has no wiring for the light in the boot? I have the bulb casing and bulb but there is no wiring for it.
2012 2.0 Cdti Sri vx line.
