intellilink 950 dash centre navi speaker
Navi 950 intellilink centre dash speaker
Does a navi 950 intellilink system have the output for to fit a centre speaker. If it can be added is there a plug tied back somewhere on the loom or is it a matter of adding the pins and extra wires to the connector on the rear of the 950 unit.
the centre speaker runs off the door speakers (unless you have the infinity system) all you can do is pull the radio out and see if you can find the connector.
my VXR 950 loom did not have the centre speaker wiring, but as Rusty said it's just one wire from the left speaker and one from the right speaker
Infinity sound system has the centrte dash speaker, which runs drect from the amp.
So to add the centre speaker u take a + from one front door speaker output and a negative from the other is that correct?? Do I do this at the wiring connector on the rear of the 950 unit.
Does anyone have a wiring diagram for the 950 showing the speaker outputs including the centre speaker.
That is correct.
I've posted it before on the forum so try the search bar.
  cd 400 upgrade to navi 600 need help goose9029 6 10,034 14:th-Feb-2024, 07:52:16
  vin relearn navi 600 geoffp 1 4,002 5:th-Jul-2021, 15:38:22
Last Post: livo
  Navi 650 bluetooth and reverse camera mislav_os 30 37,190 9:th-Jun-2021, 16:08:07
  Navi 950 retrofit to Buick Encore vibalt 3 13,452 21:st-Jul-2020, 19:02:30
  navi 500 programming tzr608 14 22,087 15:th-Mar-2020, 23:15:54
  Options to replace Navi 400 in 62 plate Astra Atarius 7 12,276 12:th-Sep-2018, 07:04:30
  Cd500 navi Davy20121957 5 15,029 23:rd-Jun-2018, 16:54:25
Last Post: tzr608
  Navi radio and larger instrument display changing gazz292 54 98,460 28:th-Apr-2018, 10:47:52
Last Post: gazz292
  Navi 900 to I-link/MyLink 950 Wiring diagram Tylerrattv 7 13,285 8:th-Sep-2017, 15:50:06
  Installing 2013 intellilink nav unit and trim on a 2010 Insignia i.rosca 5 13,350 13:th-Apr-2017, 13:52:33
Last Post: i.rosca
