Dash LEDS
have found out any LEDS that will work in the dash yet? I want to change from white.
HOW-TO Turn on hidden options on IPC (DASH)
3" centre dash speaker
Has anyone got one?
Yellow light on dash - car with lock through it
just been running kids around tonight and when daughter got in car and I went to start car the yellow light on the dash with the car and lock through it flashed and car wouldn't start...removed key and tried again and started no problem...I know this is the immobilizer but is it doing this because the battery in the key needs changing or is it something completely different??
Dash cam power supply
Ok so after some twerp decided to cover my windscreen and bonnet with tomato sauce while I was at work. I am now looking at dash cams,
I have found this one on ebay http://www.ebay.co.uk/itm/251749193955?_...EBIDX%3AIT.
With it having the function to constantly record and has a battery drain prevention device I just wondered if I would be able to wire it into the lights in the roof instead of running down the a pillar/door.
Centre Dash Trim
Anyone got an idea how much autovaux would charge for the centre dash trim and if they can get one? I'd obviously need the part number but don't know what it is.
I really want the gloss black trim
[Image: http://images.tapatalk-cdn.com/15/06/12/...483423.jpg]
I'm sure I've seen one that's completely gloss back in GTC
I could be looking forever on eBay to find one.....
Go Pro Dash Cam
Hey guys
So I'm planning on using my partners Go Pro as a dash cam and was just going to stick it to the windscreen just a bit below where the rear view mirror is...anyone think this is a good place to put it or does anyone else use one for this (or use dash cams in general) and know of a better place to mount it?
Dash Dials
When I switch the ignition on the both dial do an almost complete revolution and then settle back along with the dash lights illuminated then go out.
Is this the norm?
DP
dash cam as a reversing camera
a guy in halfrauds said that if you get a high enough spec dash cam for boot you can get it to relay to the cars screen (if fitted lol) when in reverse, does that sound right,
its a shame you cant get a reversing numberplate lamp that is also a boot dash cam
No Dash Lights or Instruments / battery off
I have just fitted a tow bar wiring kit to my gtc 1.4
I took of the negative battery connection.
Added the wiring as per instructions now when i start the car i have no dials or lights on dash no sat nav nothing as if a fuse had blown but they are all in order. I undone the wiring but this has not cured the problem.
Could this be down to the battery being off or is it more drastic.
If it is the battery can i do a simple fix ie reset or is it a case of in to the dealership :(
