vagepap - Replies:
Schematic Diagram needed
Good evening to all. Thanks for accepting me to your forum.
I have a problem with my Astra J and I need the radio/nav schematic manual.
I cannot open the links for the schematics in this site:
http://workshop-manuals.com/vauxhall/ast...itle_page/
My problem is that randomly ( especially when the ambient temperature is rising - during summer for example) the RH speakers are producing a heavily distorted audio. This is irrespective of the audio source i.e. radio
Navi 900 to I-link/MyLink 950 Wiring diagram
I want to upgrade my head unit to the I-link 950 unit.
So far i know its possible and have successfully changed the VIN on a MyLink unit out of a commodore (I'm an Aussie) and it does turn on and the radio works.
I'm 99% sure that the units store the VIN on the same chip on all devices (made by Panasonic).
I just need a wiring diagram from a Navi 900 and from a I-link 950 and then hopefully i can write a how to once i have done it.
kebibg - Replies:
Please for help with wiring diagram.
[attachment=960][attachment=961][attachment=962]
I know wiring diagrams not free in the net and need to have account for that.
I need badly schematic of blind spot alert of Insignia 2014.
I have a check procedure for my error but don't have a wiring.
Can attach procedure for testing but he is partial usable because don't have wiring codes and connectors.
That i thing in astra J system will be the same.My error are U18A6.
If anyone can help will be
cubez0 - Replies:
Wiring Diagram [Internal Lights]
Does anyone have a wiring diagram for the astra J?
I am looking for ignition power for a dash cam, hopefully within the map lights area?
Badenj - Replies:
Wiring diagram
hi can anyone provide me with a wiring diagram for the a20dth engine.
I need to find what pin on the ecu is for the lambda sensor and test from that end.
Many thanks.
EricMod - Replies:
Astra J Coming Home Module / Key Signal Diagram
Hey there guys!
I wanted to retrofit a Coming Home Module for my Astra J (A16XER).
The aftermarket Module needs a „door open“ signal to trigger the relay inside of it. I looked up in Autodata and searched the Internet but I cant find any useful information unfortunately. All I know is, the Body Control Module (BCM) should process the Signals but there are many cables to measure them all for my needed voltage signal.
Does somebody know or has a Wiring diagram/Pin assingment picture or something
aurega - Replies:
ECO button connector diagram (start/stop)
Hello,
is here anyone how knows which cable is signal, plus and negativ for Start/stop system on this ECO button and connector?
Is there any existing diagram please?
Many thanks !
Milo629 - Replies:
Astra J Instrument Cluster 32pin wiring diagram
milozic - Replies:
Front PDC wiring diagram
Hi. I need help. I want to retrofit front and rear PDC. I installed module, switch, rear wiring harness(bumper and loom to the module) and front bumper wiring. Now i need to make some custom loom, to connect front bumper harness to the car. I have connectors, i just need some wiring diagram, to know, where to connect wires. I know, that this loom connect under the battery to the other wirings, but anyone have some wiring diagram, to know where to connect which wire?
[attachment=1235]
[attachme
Leady78 - Replies:
Side turning/indicator wiring diagram to help install sequential LED DRL strip.
Hello all,
I am planning to fit/install front sequential LED light strip which has the function of DRL & indicator signals. I need help or advise on how best to do this. Is it best to try and tap into the side panel indicator or the lower front indicator that is next to the fog light?
Any help would be appreciated, I have experience in wiring other lights on the car but this is the first time I have looked at fitting a sequential LED light strip that needs to use the indicators as a addit
