cluster 32pin instrument j wiring astra diagram
Astra J Instrument Cluster 32pin wiring diagram
Hello,
I hope somebody has the pinout for the IPC and can upload it for me, for example i found this nice picture in the other thread about an other connector.
The engine code is A14NET if it matters, thank you.
[alıntı='Milo629' pid='50287' tarih bilgisi='1548165313']
Merhaba,
Umarım birisi IPC'nin pinout'una sahiptir ve onu benim için yükleyebilir, örneğin diğer başlıkta başka bir başlık hakkında güzel bir resim buldum .
Önemliyse motor kodu A14NET,teşekkür ederim.
[/alıntı]
Bana da lazım lütfen yardım edin.
I need it too plase send me
Gösterge pin diagramı elinde olan var mı?
  TPMS on Astra J GTC milozic 0 3,619 14:th-May-2023, 18:58:09
Last Post: milozic
  Digital cluster (virtual cockpit) retrofit milozic 5 12,881 30:th-Apr-2023, 19:51:49
Last Post: milozic
  insignia cluster into astra? Tylerrattv 48 67,311 30:th-Jul-2021, 18:27:37
Last Post: theendfear
  tow bar wiring Dicko 57 64,407 6:th-Oct-2020, 07:25:45
  Front PDC Wiring leeso 1 4,153 15:th-Jan-2020, 19:43:02
  Rear camera fit on Opel astra sports tourer info ;) Alienbv 24 30,677 26:th-Dec-2019, 13:00:29
  parking and cluster upgrade Maniacu 5 13,816 8:th-Sep-2019, 13:06:46
Last Post: andre_rf
  astra k cluster on astra j Maniacu 2 10,088 6:th-Jun-2019, 14:37:10
Last Post: Maniacu
QuickHeat & wiring W.I.P. Lansa 0 4,896 24:th-Feb-2019, 17:51:30
Last Post: Lansa
  Astra J Coming Home Module / Key Signal Diagram EricMod 9 23,734 16:th-Jan-2019, 12:20:43
8 User(s) read this thread:
Rusty2009 (5:th-May-2025, 19:33:38), Big Dave2 (8:th-May-2025, 12:54:09), milozic (24:th-Jan-2026, 20:41:17), jas7c5-2008 (12:th-Mar-2026, 20:53:39), Buashei (4:th-Feb-2026, 12:22:04), dellpiron (5:th-Dec-2025, 22:59:19), TonyP (4:th-Nov-2025, 21:59:50), SKYBOX (5:th-Apr-2026, 11:34:52)
