cluster 32pin instrument j wiring astra diagram
Astra J Instrument Cluster 32pin wiring diagram
Hello,
I hope somebody has the pinout for the IPC and can upload it for me, for example i found this nice picture in the other thread about an other connector.
The engine code is A14NET if it matters, thank you.
[alıntı='Milo629' pid='50287' tarih bilgisi='1548165313']
Merhaba,
Umarım birisi IPC'nin pinout'una sahiptir ve onu benim için yükleyebilir, örneğin diğer başlıkta başka bir başlık hakkında güzel bir resim buldum .
Önemliyse motor kodu A14NET,teşekkür ederim.
[/alıntı]
Bana da lazım lütfen yardım edin.
I need it too plase send me
Gösterge pin diagramı elinde olan var mı?
  TPMS on Astra J GTC milozic 0 4,027 14:th-May-2023, 18:58:09
Last Post: milozic
  Digital cluster (virtual cockpit) retrofit milozic 5 13,911 30:th-Apr-2023, 19:51:49
Last Post: milozic
  insignia cluster into astra? Tylerrattv 48 71,530 30:th-Jul-2021, 18:27:37
Last Post: theendfear
  tow bar wiring Dicko 57 69,278 6:th-Oct-2020, 07:25:45
  Front PDC Wiring leeso 1 4,678 15:th-Jan-2020, 19:43:02
  Rear camera fit on Opel astra sports tourer info ;) Alienbv 24 33,011 26:th-Dec-2019, 13:00:29
  parking and cluster upgrade Maniacu 5 14,562 8:th-Sep-2019, 13:06:46
Last Post: andre_rf
  astra k cluster on astra j Maniacu 2 10,682 6:th-Jun-2019, 14:37:10
Last Post: Maniacu
QuickHeat & wiring W.I.P. Lansa 0 5,383 24:th-Feb-2019, 17:51:30
Last Post: Lansa
  Astra J Coming Home Module / Key Signal Diagram EricMod 9 25,009 16:th-Jan-2019, 12:20:43
7 User(s) read this thread:
ciore72 (5:th-May-2026, 17:12:15), milozic (24:th-Jan-2026, 20:41:17), jas7c5-2008 (13:th-Jul-2026, 20:27:03), Buashei (4:th-Feb-2026, 12:22:04), dellpiron (5:th-Dec-2025, 22:59:19), TonyP (4:th-Nov-2025, 21:59:50), SKYBOX (12:th-Jul-2026, 15:05:28)
