24:th-Mar-2016, 22:09:01
They no longer sell them I think
Tags |
to led door j the astra free error for how 5 drl |
HOW-TO LED DRL Error free for the Astra-J 5 door
24:th-Mar-2016, 22:34:53
As I said, for the cost I expected better
26:th-Mar-2016, 04:57:36
Hi, i have some dlectrical training and as i see it, you all are using load resistors in paralel.
Why? If u used them in serial to leds they would need be just 5w, not 50w, as i reckon. How does the canbus detect them exactly? Regards...
26:th-Mar-2016, 09:02:48
Can bus doesn't care if you put candles in there. It's just a bus made from couple of wires. But if iremember correctly then whatever controls lights needs around 0.7 amp draw in drl mode to not trigger warning.
26:th-Mar-2016, 09:59:30
two loads are added to make the DRL dim down error free
add one load only and ether side light or drl mode with have an error message and the drl will stay in ether drl mode or side light mode only two loads solves this problem and makes the drl dim down and work in drl mode error free the drl is also linked to the main beam headlight bulb in side light mode so 50w loads are used to combat this and to stop the cambus finding low wattage and giving errors
26:th-Mar-2016, 14:22:24
That makes sense, but why not put one load in serial at negative line? Should not that make the same result?
I just played a bit with lights on my car.
Rear right tailgate lights also throw code 22, same as front right dlr. code 21 for left. Guest dlr+4 tailgate lights are on the same canbus and it measures ampere load. All on one side would have common negative. Does that makes sense? Sent from my iPhone using Tapatalk
26:th-Mar-2016, 19:24:58
YEP tail lights are also linked to the drl
you can try but but when i tryed that the drl just stayed bright and would not dim
27:th-Mar-2016, 22:07:21
Hey guys, I'm looking at upgrading my drl's to led's with the help from this post, was just wondering if someone could post up a new link with the bulbs you find best to use, I've tried clicking on previous link from hid s direct however it says page not found, guessing they don't do that bulb anymore as it was from atleast a year ago haha
Thanks in advance
28:th-Mar-2016, 08:00:01
28:th-Mar-2016, 18:53:32
Cheers rusty will get them ordered ?
30:th-Mar-2016, 22:55:01
Are these OK to use as the loads? I know I need 4 of them
http://m.ebay.co.uk/itm/1pcs-50W-6ohm-Lo...nav=SEARCH Thanks
7:th-Apr-2016, 19:19:13
Ok so I have tried to fit my led drl's today and I can't get the sidelight to work on it, it comes on for about 2 seconds then turns off, tried changing everything round but just won't stay on, but didn't get it to flick between both at all, it's for hid s direct, any suggestions?
10:th-Apr-2016, 20:12:47
Astra j, load resistors was added
11:th-Apr-2016, 09:50:57
Has anybody had any experience with these?
http://pages.ebay.com/link/?nav=item.vie...04&alt=web Sent from my LG G4 using Tapatalk
11:th-Apr-2016, 12:40:27
(11:th-Apr-2016, 09:50:57)bhalay207 Wrote: Has anybody had any experience with these? A few have tried them the holder doesn't fit Sent from my iPhone using Tapatalk Astra-J 2.0 CDTI S/S
13:th-Apr-2016, 10:27:33
(11:th-Apr-2016, 09:08:17)tucpal Wrote: What bulbs have you used and you did add. two loads Yeah two loads was added to each bulb and I used these bulbs http://www.hids-direct.co.uk/r580-w21-5w...s-2-bulbs/
13:th-Apr-2016, 12:04:50
Bulbs are ok I fitted some to a gtc the other day so your wiring is wrong so recheck that
14:th-Apr-2016, 07:58:52
Ok will do thanks
26:th-Apr-2016, 00:10:18
Whats happening with images on this post? HAlf of them are missing, ex. Schematics from 1st page, bulb examples from 2nd page.
I just wanted to start modding my DLRs but have no info
27:th-Apr-2016, 13:11:14
(26:th-Apr-2016, 00:10:18)milika Wrote: Whats happening with images on this post? HAlf of them are missing, ex. Schematics from 1st page, bulb examples from 2nd page. All images loaded for me apart from 1 image that has been deleted by Lewis. Sent from my iPhone using Tapatalk Astra-J 2.0 CDTI S/S
14:th-Oct-2016, 00:08:54
Would this set up also be the same for a Insignia as well? Pre facelift model.
25:th-Oct-2016, 21:13:00
Hello,
I bought the CAN bus LEDS http://www.dobry-obchod.cz/produkt/95243...vouvlakno/ but ofc there is error on the dash-board. Only solution which I found is to add resistors. I don't want to drill the hole into the headlight back. Is it possible to add resistors into the fuse box ? or any other place on the way to CANbus check part? Sorry for my English... I'm from Czech republic. Thanks, Jan
26:th-Oct-2016, 07:52:49
(25:th-Oct-2016, 21:13:00)aurega Wrote: Hello, No canbus bulbs work without errors on the J DRL's. You could try tapping a resistor onto Grey/Dark-Blue wire coming out pin 9 on the headlight plug. Your English is very good by the way. Astra-J 2.0 CDTI S/S
26:th-Oct-2016, 13:54:59
(26:th-Oct-2016, 07:52:49)Rusty2009 Wrote:(25:th-Oct-2016, 21:13:00)aurega Wrote: Hello, Hello, many thx for reply !!! do you have any photo of this plug? And you mean to add this resistor on both? gray one and blue one? Thanks, Jan
26:th-Oct-2016, 16:39:51
(26:th-Oct-2016, 13:54:59)aurega Wrote:(26:th-Oct-2016, 07:52:49)Rusty2009 Wrote:(25:th-Oct-2016, 21:13:00)aurega Wrote: Hello, Yes I've attached a image showing the plug and numbers. Ok so the wires should be Grey/Dark Blue on left headlamp (one wire It's just has a tracer strip) Dark Blue/Brown on right headlamp (one wire It's just has a tracer strip) Astra-J 2.0 CDTI S/S
6:th-Nov-2016, 22:54:02
Thank you - but I think this is too high-tech for me... I don't want to mess things up :(
I have taken a look at the internet and found these - https://www.aliexpress.com/item/High-Qua...8d811aa42b They have 15W - is that enough for the car computer? Thanks, Jan
6:th-Nov-2016, 23:01:15
Hids direct have just brought out a new LED DRL with new chip which is meant to be error, another chap has brought a set as soon as I hear the results I'll post back here.
6:th-Nov-2016, 23:04:51
8:th-Nov-2016, 09:27:24
(6:th-Nov-2016, 23:01:15)Rusty2009 Wrote: Hids direct have just brought out a new LED DRL with new chip which is meant to be error, another chap has brought a set as soon as I hear the results I'll post back here. Hello, in the meantime can you please send me the link on those new LEDs? If its possible ofc. Thanks, Jan
8:th-Nov-2016, 21:36:55
(8:th-Nov-2016, 09:27:24)aurega Wrote:(6:th-Nov-2016, 23:01:15)Rusty2009 Wrote: Hids direct have just brought out a new LED DRL with new chip which is meant to be error, another chap has brought a set as soon as I hear the results I'll post back here. Of course. http://www.hids-direct.co.uk/r580-w21-5w...air-white/ Sent from my iPhone using Tapatalk Astra-J 2.0 CDTI S/S
9:th-Nov-2016, 01:30:53
(8:th-Nov-2016, 21:36:55)Rusty2009 Wrote:(8:th-Nov-2016, 09:27:24)aurega Wrote:(6:th-Nov-2016, 23:01:15)Rusty2009 Wrote: Hids direct have just brought out a new LED DRL with new chip which is meant to be error, another chap has brought a set as soon as I hear the results I'll post back here. Waiting on feedback on the 5 door as well - might consider getting. The one I have currently are error free LED T20, but do not dim down. Had it for a year, left side is not working on side light mode anymore - which rightfully gives an error now. Just ordered replacements - its about half the price of the HID direct T20 LEDs.
9:th-Nov-2016, 08:09:44
I pay £10 for halogen bulbs from Halfords so £15 for LED's seems reasonable to me if they do work error free without the need for additional resistors.
9:th-Nov-2016, 09:31:20
(8:th-Nov-2016, 21:36:55)Rusty2009 Wrote:(8:th-Nov-2016, 09:27:24)aurega Wrote:(6:th-Nov-2016, 23:01:15)Rusty2009 Wrote: Hids direct have just brought out a new LED DRL with new chip which is meant to be error, another chap has brought a set as soon as I hear the results I'll post back here. Many thanks ! looks awesome ... I hope that they will going to work without any error. Also I hope that this shop will send me these to Czech Looking forward to have the feedback ! Thanks, Jan
9:th-Nov-2016, 09:57:58
They say they post worldwide but import duty's maybe charged which they aren't responsible for.
9:th-Nov-2016, 10:14:04
11:th-Nov-2016, 20:48:38
11:th-Nov-2016, 21:44:46
1 person no errors another person errors I did suggest they spin them 180 but not heard anything back yet
11:th-Nov-2016, 22:14:38
12:th-Nov-2016, 11:42:16
14:th-Nov-2016, 00:32:06
The reviews look promising on those bulbs. For £15 it's worth a punt
14:th-Nov-2016, 13:14:19
Got this from what @Tonto posted in another thread.
(14:th-Nov-2016, 12:33:14)Tonto Wrote: Just a little update for the leds from hids direct. @Jonathaneuk had them and he said initially he got an error pop up but they've been fine ever since and they're bright! Astra-J 2.0 CDTI S/S
14:th-Nov-2016, 19:22:52
(14:th-Nov-2016, 13:14:19)Rusty2009 Wrote: Got this from what @Tonto posted in another thread. Great ! looks really good! I give them try .... Its £23.45 for me because of shipping. Thanks.
22:nd-Nov-2016, 18:24:01
Hello again ! today I have received these bulbs from Hids direct - but on the backside there is number 4014 and not 3014 as on the web.
Is that correct ? Should I return them? Thanks
12:th-Feb-2017, 23:50:39
How to ambient door lights | tucpal | 214 | 146,096 |
28:th-Mar-2021, 00:48:32 Last Post: Benk91 |
Projector HID retro fit Astra j 5 door | tucpal | 88 | 77,892 |
4:th-Jun-2020, 09:01:15 Last Post: Rusty2009 |
Upgrading Fog lights on J 5 door | GarethMyers14 | 4 | 9,340 |
17:th-Nov-2017, 02:25:38 Last Post: sanj424 |
Who read this thread? |
3 User(s) read this thread: |
Big Dave2 (25:th-Jan-2024, 12:44:56), loeb (22:nd-Mar-2024, 21:08:59), bill33 (29:th-Mar-2024, 03:24:35) |
