lights door j fog upgrading 5 on
Upgrading Fog lights on J 5 door
Has anybody ever swapped over their fog lights to LED bulbs? It so, is it necessary for the bumper to be removed, or are the fog lights accesable by hand?
What bulbs are they best, as I've been told there H3 fitments. Can this be confirmed
do you have pre-facelift or facelift?
I am also interested in upgrading fog lights. I own a 5 door facelift. OP-Com seams to be useless, only read out failures.
I heard about Happy fog module but dont know if it works an facelift
From a fault-code perspective you can just change them without issue as the BCM doesn't seem to know whether these lights malfunction. So no extra resistor/'canbus compatibility' bullshit required.
(17:th-Apr-2017, 14:58:38)GarethMyers14 Wrote: Has anybody ever swapped over their fog lights to LED bulbs? It so, is it necessary for the bumper to be removed, or are the fog lights accesable by hand?
(3:rd-Nov-2017, 19:50:48)daydreamer33 Wrote: I am also interested in upgrading fog lights. I own a 5 door facelift. OP-Com seams to be useless, only read out failures.
I have a 5 door facelift - which uses H11 bulbs. I recently swapped to LED h11 bulbs - mostly plug and play with good fitment and no errors as fogs are not canbus monitored. 2 ways to go about it
  1. reaching under the bumper - ok for removing and installing halogen bulbs but LED has bigger housing from heatsink so difficult to put in that way.
  2. I then removed the fog light housing in the bumper (2 screws) and pulled out to install. Easy job. Also gives you visibility on where to place your led driver.
  HOW-TO LED DRL Error free for the Astra-J 5 door tucpal 222 214,772 15:th-Aug-2025, 19:10:30
  How to ambient door lights tucpal 214 208,190 28:th-Mar-2021, 00:48:32
Last Post: Benk91
  how to install FOOT WELL LIGHTS tucpal 136 125,262 22:nd-Feb-2021, 08:00:17
  Super Bright Boot Lights sheppy1 26 28,438 12:th-Nov-2020, 17:54:59
Last Post: Arkanggel10
  Projector HID retro fit Astra j 5 door tucpal 88 98,978 4:th-Jun-2020, 09:01:15
  How to fit courtesy lights in mirrors kyle-astra-j 21 25,871 18:th-Feb-2018, 06:15:13
Last Post: Leigh0274
  How to Puddle Lights Rusty2009 22 33,769 6:th-Nov-2017, 20:16:44
Last Post: zzattack
  HOW TO LED TAIL LIGHTS tucpal 31 34,969 24:th-Oct-2017, 12:29:02
Last Post: Grimo72
  how to upgrade interior lights to SMD LED tucpal 91 83,935 2:nd-Aug-2016, 13:42:21
